Trouble compiling hex for pic12f629
kingdragon6977
trouble comp. hex for pic12f629
PostPosted: Tue May 22, 2012 8:25 pm     Reply with quote
Ok we're to start trying to program pic12f629 for Xbox 360 rf sync. The pic accepted the program but when I plugged it in didn't work. Then I found out .hex wasn't setup for 12f629, was for 16fxx, so I disassembled but can't seem to compile. Any thoughts ?
PostPosted: Fri May 25, 2012 6:44 pm     Reply with quote
Well It ain't rocket science...
1) use the PIC the code was designed for....you didn't say (xxx)...
2) since you've disassembled the code, compare every line and PIC init/setup to see what's different...
3) You better confirm the code WILL work on a 629 and NOT just on the xxx PIC !!! Not all PICs are the same..
