18f67k22 sosc dig low high
bolubeyi
PostPosted: Fri May 25, 2012 6:13 am     Reply with quote
I use 18f67k22 but I don't set port C1 for pwm.
There are something but i don't understand and i don't use for pwm or io. SOSC_LOW,SOSC_DIG,SOSC_HIGH ? How can do this?
PostPosted: Fri May 25, 2012 12:49 pm     Reply with quote
SOSC_HIGH and SOSC_LOW are used if you use an external oscillator
circuit (crystal, etc.) for Timer1.
To use the SOSC pins as normal i/o, just select SOSC_DIG for the #fuses.
The reason you need to select SOSC_DIG, is because the default state
for the 18F67K22 is to enable SOSC_HIGH (which enables the Timer1
oscillator in high power mode). But most people don't want that.
Most people should use SOSC_DIG.
