RTOS_Disable() & RTOS Enable()
waheed
PostPosted: Tue May 22, 2012 12:36 am     Reply with quote
Controller: PIC 18f452
How to use these Functions? Info Provided in the CCS Manual is insufficient.
I have tried using it in a RTOS Task like this:
#task (rate=100us, max=50us)
void read_adc()
float32 Volts;
count++;
adc_value = read_adc();
Volts = (float32)adc_value*3000;
Volts = Volts/1024;
Volts_add = Volts_add + Volts;
Volts_final= Volts_add/(float32)count;
#task (rate=100us, max=20us)
if (count==100)
RTOS_Enable(LCD_Update);
void LCD_Update()
count=0;
Volts_add=0;
dt_lcd_gotoxy(0,4);
printf(dt_lcd_printchar"Voltage = %fmV            ",Volts_final); /* send to LCD*/
dt_lcd_gotoxy(0,3);
printf(dt_lcd_printchar,"Bits = %Lu            ",bits);
sq_value=(sqrt(Volts_final)/100)*2.235;
dt_lcd_gotoxy(0,5);
printf(dt_lcd_printchar,"Sq. Vol. = %f        ",sq_value);
dt_lcd_gotoxy(0,6);
printf(dt_lcd_printchar,"PWM1 = %f%% ",PWM1_duty);
dt_lcd_gotoxy(0,7);
printf(dt_lcd_printchar,"PWM2 = %f%% ",PWM2_duty);
What I wanted this program to do is, read the value of ADC 100 times, takes the average and enables LCD_Update Task.
But it gives error that the following part needs declaration:
if (count==100)
PostPosted: Tue May 22, 2012 1:23 am     Reply with quote
You would....
A function needs to be declared _before_ you can reference it. You need to create a function prototype for the LCD_Update function _before_ you try to reference it.
Separately, is the section 'if (count==100)' a function?. It has to be to be used by #task, and isn't as you show it.
waheed
PostPosted: Tue May 22, 2012 3:15 am     Reply with quote
I have tried doing it this way. But it still gives error:
"Undefined identifier LCD_Update"
#task (rate=100us, max= 50us)
void LCD_Enable()
if (count==1024)
   rtos_enable(LCD_update);
void LCD_update()
count=0;
Volts_add=0;
dt_lcd_gotoxy(0,4);
printf(dt_lcd_printchar"Voltage = %fmV            ",Volts); /* send to LCD*/
dt_lcd_gotoxy(0,3);
sq_value=(sqrt(Volts)/100)*2.235;
dt_lcd_gotoxy(0,5);
dt_lcd_gotoxy(0,6);
dt_lcd_gotoxy(0,7);
void LCD_Disable()
rtos_disable(LCD_update);
PostPosted: Tue May 22, 2012 6:41 am     Reply with quote
_As I said_.
"A function needs to be declared _before_ you can reference it. You need to create a function prototype for the LCD_Update function _before_ you try to reference it."
Still applies.
waheed
PostPosted: Tue May 22, 2012 10:29 pm     Reply with quote
Dear Ttelmah,
Will you please elaborate a little.
Should LCD_Update function be outside the task?
All Function are Enabled by default. Is there any way to Disable a specific task before the execution of rtos?
If I write LCD_Update before the LCD_Enable function, then LCD_Update task will run first and then how can I control it _ provided that all task are enabled by default...
Mike Walne
PostPosted: Wed May 23, 2012 3:04 am     Reply with quote
I think you've got a 'C' issue NOT an RTOS one.
Have you got a line like this, near the the top of your code, with all the other prototypes in ALL relevant files?
void LCD_update();
I know CCS is not entirely consistent about this, and often the compiler accepts code without prototypes.
Why not include count test as part of the LCD_update() task?
void LCD_update()
  if (count==100)
   .... rest of LCD_update code as is
Simply do the test, ignore the bulk of the code if the test fails.
That way you don't have to worry about enabling and disabling the task.
You've got three different values that you're testing count for; 100, 1000, 1024 sprinkled through your code snippets. I'm assuming that you know what you're final intention is.
Mike
waheed
PostPosted: Wed May 23, 2012 4:15 am     Reply with quote
void LCD_update();
No, I haven't written a line like this. Should I include this?
void LCD_update()
  if (count==100)
I have already tried this. This works fine, just trying to figure out how the RTOS _Enable() & RTOS_Disable() function work.
I was just testing the code and didn't care for the values. By the way, the value, I am going to use is 1024.
PostPosted: Wed May 23, 2012 5:24 am     Reply with quote
waheed wrote:
void LCD_update();
Get back to your C study book and look up the difference between a 'function definition' and a 'function declaration'.
It is a little bit confusing but this is such basic C knowledge that I'm not going to repeat what is in every textbook. Just remember that before you can use a function the compiler has to 'know' what the input and output parameters are. So when processing your source files the compiler will go through it top to bottom and when it comes to an unknown function it will stop instead of being smart and scan through the rest of the file to find the unknown function. So it is up to you, as a programmer, to make sure the function name is known before it is being used.
PostPosted: Wed May 23, 2012 8:48 am     Reply with quote
Mike
Actually, I think this is one area, where CCS, sticks _exactly_ to the letter of C.
You must _either_ have a declaration, or a definition before the function is used. A definition, implicitly creates a declaration, if one does not already exist, so if you have the definition, before using the routine, a further declaration is not required. Types used in declarations and definitions must match (this is an ANSI requirement not in C originally).
Mike Walne
PostPosted: Wed May 23, 2012 11:10 am     Reply with quote
Thanks Ttelmah, you've cleared up a confusion in my mind.
I'm relatively new to 'C', and learn something every day.
So this code compiles OK without a prototype
//     Prototypes
#include <18F452.h>
void test_function() {}
while (1)  { test_function(); }
And this doesn't.
//     Prototypes
#include <18F452.h>
I thought it was CCS not being strict.
Thanks again.
Mike
