pcwhd compiler problems
matt99199
PostPosted: Mon May 21, 2012 4:54 pm     Reply with quote
Hello all, I am very new at programming mcu's and I have a problem with the pic c compiler. I write the simple code:
#include <16f628a.h>
while(1) {
output_high(pin_a1);
and there is no errors, but the code doesn't work! I know my programmer works and everything because I made code with assembly and it worked fine. I don't know why this wouldn't work but I can't figure it out.
PostPosted: Mon May 21, 2012 5:02 pm     Reply with quote
You are missing #fuses and #use delay(). Look at the sample code in
this thread for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=32580
