on7nh
dspic30f6014a and I2C |
Posted: Mon May 21, 2012 7:55 am |
hello,
have someboby experience with a dspic30f6014a and i2c?
i have this project,
the processor is running over it without problem, but the result is always 0
pull up resistors are 4.7k, i see on a scoop the request from the cpu, and i see the TC74A5 answering.
#include <30f6014a.h>
#DEVICE ADC=12
#FUSES EC_PLL8 //XT Crystal Oscillator mode with 8X PLL
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES PUT64 //Power On Reset Timer value 64ms
#FUSES NOMCLR //Master Clear pin used for I/O
#USE DELAY(Clock=80M) //10Mhz Crystal with 8X PLL (Is that right?)
#use i2c(master, sda = PIN_G3, scl = PIN_G2, force_hw)
#USE RS232(UART1,Baud=115200,Parity=N,Bits=8)
#include <t6963_test.C>
#include <graphics.c>
#include <Math.h>
/////////////////// Variabelen /////////////////
int ack;
Float Temperatuur;
void Prnt_display();
void Analoog_Conversie();
void Temperatuur_lezen();
{ // lezen TC74A5 //
i2c_start();
ack = i2c_write(0x9A);
ack = i2c_write(0x00);
/* send start again */
i2c_start();
ack = i2c_write(0x9B);
Temperatuur = i2c_read(0);
i2c_stop();
printf("temp %f \r\n",temperatuur/10);
setup_adc_ports(sAN2 | sAN3 | sAN4 | sAN5 );
setup_adc(ADC_CLOCK_DIV_64 | ADC_TAD_MUL_31);
printf("%c[2J%c[H",27,27);
printf("Booting \n\r");
while(1){
Prnt_display();
Posted: Mon May 21, 2012 8:25 am |
Obvious first question:
Why are you dividing the value by 10?.
The chip returns the temperature as a _signed_ integer value from +127 to -65 (specification limit in the -ve direction). In degrees. No scale by ten involved.
To display the temperature for this, you want:
printf("temp %d \n\r",temperatuur);
No division, and use the signed output format.
Assuming your room is at (say) 20C, then you would only get perhaps '1' as an output with your division, since this is being performed using integer maths.
Might be the whole problem....
If your serial works, then this verified your clockrate is OK (you query this).
What version of the 7C74A5 have you got?. Needs to be the TC74A5-5.0VCT or the TC74A5-5.0VAT.
The chip requires you to wait for 250mSec after power on, before a reading will be ready.
The _maximum_ specified clock speed for the bus, is 100KHz. I'd explicitly specify a rate below this:
#use i2c(master, slow=80000, sda = PIN_G3, scl = PIN_G2, force_hw)
I'd explicitly ensure the device is out of shutdown:
i2c_start();
i2c_write(0x9A);
i2c_write(0x01);
i2c_write(0); //set command register to 0 to ensure chip is on
i2c_stop();
The data sheet says this bit should be 0 at POR, but worth being sure....
Try running PCM_programmers I2C bus scanner program, and verify you do get an ACK from the chip.
on7nh
Posted: Mon May 21, 2012 11:54 pm |
i did yesterday some tests,
dividing was...i was thinking the TC74 was working wit a decimal...NOT..
the TC74A5-5.0VAT is responding the correct vallue (see picture) but the controller give me always a 0
clockrate is changed to 80000
pull up resistors are now 10k
