String fprintf and fputc (fputc works, printf does not)
mtsoule
PostPosted: Sun May 20, 2012 9:47 am     Reply with quote
ok, with this code my output is
{0{}}
I expect the output to be
{8{Settings}}
which tells me the length of my string is 0, however if I uncomment the fputc statement, I get the expected data.
I have, for simplicity, taken out all of the error checking and other non essential code.
Compiler version is 4.132
while(BT_inchar != '\n')
   while(!BT_Inchar_Ready)
      BT_Inchar_Ready = 0;
      RX_Buffer[RX_ctr] = BT_inchar;
      RX_ctr++;
   //   fputc(BT_inchar,prog);
      fprintf(prog,"{%i{%s}}",strlen(RX_buffer), RX_Buffer);
here is my isr
#int_RDA
void  RDA_isr(void)
BT_Inchar = getc(BT);
BT_Inchar_Ready = 1;
bkamen
PostPosted: Sun May 20, 2012 5:47 pm     Reply with quote
Keep in mind using any string stuff in fprintf (or just printf) requires the string be NULL terminated.
Otherwise, the printf can run off into la-la land.
So when you get your string, before printing it, you need to make sure there's a zero at the end.
-Ben
mtsoule
Got it!!
PostPosted: Mon May 21, 2012 4:39 am     Reply with quote
Thanks Ben, that was it! i ended up moving my "Buffer Filler" to the ISR (i hate putting it there) i like to go in to the ISR and get out. But i found it works best for my app.
Basically here is what i have now in the ISR
#int_RDA
void  RDA_isr(void)
if((Packet == Packet_Count) && (BT_Inchar != '\r') && (BT_Inchar != '\n'))
   RX_Buffer[RX_ctr] = BT_Inchar;
   RX_ctr++;
   RX_Buffer[RX_ctr] = 0x00;
if(BT_Inchar == '\n')
   Packet_Count++;
i do this so i can read a spific portion of the incomming stream, and i also want to throw away all the "LF's" and "CR's"
