canavaroski90
16F628A With MAX7219 |
Posted: Wed May 16, 2012 2:03 am |
Hi all. Nowadays I'm working on a 4 digit 7-segment project. I'm tired of using shift registers or 7447/7448 7-segment driver chips. Then I found this MAX7219. I know that 16F628A doesn't have hardware spi module. So I decided to create a library to use MAX7219 without using hardware or software spi communication. I've simulated all my project using ISIS and there was no problem. However when I try to assamble my project on a breadboard, bam! It doesn't work. I've checked connections, C code, power supply or anything else for a hundred times. I've changed my speed from 20 Mhz to 4 Mhz. I've disabled comparator and timer modules (I thought maybe these can cause trouble). I've set the tris register correctly for port a. But noting nothing and nothing appear on this damn 4 digit 7-segment common cathode display!
This is my library. (You can delete "wait" words. I was trying to giving some delay and I was tired of writing delay_ms(10) "
Code: | /*
* Chip : MAX7219
* Author : Burak HANÇERLİ
* Mail : bhancerli@gmail.com
* Description : MAX7219 LED Display Driver Routines - v1.0
* The Maxim MAX7219 is a led display driver. It can control up to 64 individual leds or eight
* 7-segment-display.
* Max7912 uses 3-wire to communicate with microcontroller.
* - DATA : Used to transmit data.
* - CLOCK : Used to generate clock signal which is required for transmitting each bite of data.
* - LOAD : Used to load data to the Max7913's Dual-Port SRam.
* Advantages of Max7219 :
* - Adjustable intensity. (More or less bright leds)
* - Shutdown mode (much less power consumption)
* - Test mode (To see if digits are working or not)
* - Adjustable digit number. (1 to 8 seven-segment-display)
* - Changeable decode mode. (codeB-decode-mode or no-decode-mode)
* (Look over datasheet for more detailed information)
* DESCRIPTION OF USER FUNCTIONS
* init7219() : Required for initialize MAX7219. This function have has to be called before calling any function.
* write7219(digit, data) : Writes data to the specified digit number. If Decimal Point needed on any digit, just add
128 to the data.
For example : write7219(1,3) = writes "3" to first digit.
write7219(1,131) = writes "3." to first digit.
* shutdown7219(operatingMode) : Set operatingMode = 0 to Shutdown mode
* Set operatingMode = 1 to Normal mode
* decode7219(decodeMode) : Sets digit-decode mode. code-B or no-decode mode. Look up datasheet for detailed instructions.
* For example, if user sets decodeMode = 4, (4=0b00000100), then 3. digit will be
* decoded as code-B algorithm, but other pins don't have any decode mode.
* brightness7219(brightnessLevel) : Sets brightness level of digits.
* brightnessLevel = 0 ; minimum brightness level
* brightnessLevel = 15 ; maximum brigthness level
* scanLimit7219(totalDigitNumber) : Sets number of connected digits to the MAX7219.
* test7219(testMode) : Sets 7-segment-display test-mode on or off.
testMode = 0 ; normal operation mode
testMode = 1 ; display test mode
** THIS LIBRARY CAN BE USED, DEVELOPED OR SHARED WITH REFERRING THE AUTHOR.
// CONSTANTS //
// - Connection Pins (CHANGE THESE PINS AS YOU WISH)
#define CLK PIN_A2
#define LOAD PIN_A1
#define SEND_DATA PIN_A0
// - Mode Selection
#define decode 0x09
#define brightness 0x0A
#define scanLimit 0x0B
#define shutDown 0x0C
#define dispTest 0x0F
// Firt 4 bites (not used generally)
#define firstBites 0x0
// Wait function
#define wait delay_ms(10)
long serialData=0;
void clock7219() // clock (CLK) pulse
output_low(CLK);
wait;
output_high(CLK);
void load7219() // load (LOAD) pulse
output_low(LOAD);
wait;
output_high(LOAD);
void send7219(long data) // send 16 bit data word to the 7219
int count;
for (count=0; count<16; ++count)
output_bit(SEND_DATA, shift_left(&data,2,0)); // set data (DIN) level
clock7219(); // clock data in
load7219(); // latch the last 16 bits clocked
wait;
void dataMaker(byte mode, int dataIncoming) // Standart data package function
serialData=firstBites;
serialData<<=4;
serialData|=mode;
serialData<<=8;
serialData|=dataIncoming;
send7219(serialData);
wait;
void write7219(byte digit, int data) // Send data to digits
dataMaker(digit, data);
wait;
void shutdown7219(int operatingMode)
dataMaker(shutDown,operatingMode);
wait;
void decode7219(int decodeMode)
dataMaker(decode, decodeMode);
wait;
void brightness7219(int brightnessLevel)
dataMaker(brightness, brightnessLevel);
wait;
void scanLimit7219(int totalDigitNumber)
dataMaker(scanLimit, totalDigitNumber);
wait;
void test7219(int testMode)
dataMaker(dispTest, testMode);
wait;
void init7219()
dataMaker(shutDown, 1); // No-Shutdown mode. Normal Operation mode.
wait;
dataMaker(decode, 15); // All digits are programmed as code-B decode mode.
wait;
dataMaker(scanLimit, 4); // Total digit number set to 4.
wait;
dataMaker(brightness, 15); // Full brightness.
wait;
_________________ Liberate your mind.. |
canavaroski90
Posted: Wed May 16, 2012 4:59 am |
Ok, I've solved the problem.
First of all, I couldn't find anything in datasheet about my problem. I've looked up datasheet for hundred times. There's a missing part in "Typical Application Circuit" part.
If you want to make your circuit work, then you should connect 1uF and 10uF between VDD pin of 7219 and +5V. You'll find detailed information here:
http://www.rasmicro.com/FTP/MAX7219-21%208-Digit%20LED%20Display%20Driver.pdf
PS: If you want to use this library, then you can delete wait functions (except which are in load() and clock() functions) and it works @20 Mhz. _________________ Liberate your mind.. |
John P
Posted: Wed May 16, 2012 9:49 am |
You are correct that Maxim's diagram "Typical Application Circuit" doesn't have filter capacitors, but the text mentions them under "Supply Bypassing and Wiring". They say 10uF and 0.1uF, but I think 1.0uF would also work. You really should expect capacitors on the power supply of any digital chip.
And Vdd is the +5V pin, though Maxim refers to it as V+. The filter caps go from V+ to Gnd, obviously. |
