18F2431 ADC Problem
rikotech8
18F2431 ADC Problem
PostPosted: Mon May 07, 2012 1:12 pm     Reply with quote
Hi!
Excuse my bad English!
Compiler Version: 4.114
PIC 18F2431
This code, don't work properly.
#include <18f2431.h>
#DEVICE ADC=10
#fuses nowdt, hs, nomclr
#use delay(internal = 8M)
#use rs232(baud=9600,xmit=PIN_B0,rcv=PIN_B2)
void main(){
SETUP_ADC_PORTS(ALL_ANALOG VSS_VDD);
SET_ADC_CHANNEL(1);
delay_ms(1);
long int value;
while(true){
   value=read_adc();
   printf("\fADC_VALUE = %ld",value);
   delay_ms(150);
I had test it at Isis Proteus.
The problem is that only thing appearing on the screen
is:ADC_VALUE = 0.
When I change the input voltage (via resistive divider) nothing different is printed on the screen.
Mike Walne
PostPosted: Mon May 07, 2012 2:00 pm     Reply with quote
Forget Proteus. Kick it out. It's so full of bugs, few here will even attempt to help you.
Use REAL hardware, then try again.
Mike
PS Read the CCS forum guidelines.
PostPosted: Mon May 07, 2012 2:07 pm     Reply with quote
Several comments:
1) _HS_ fuse implies an external crystal, _not_ the internal clock. Proteus doesn't complain about this, but in a real chip, it'll never work, since it won't start...
You need to be using the INTRC fuse, or INTRC_IO.
2) ADC_CLOCK_INTERNAL, is _not_ a legal ADC oscillator value above 1MHz operation. Again this needs to be changed - read the data sheet.
3) Don't declare variables inside the code. This is _not_ legal in C., Variables have to be defined at the start of a function, or at the start of a code block inside a function. CCS does not complain about this, but it often won't work.
4) As a 'comment', _do not_ enable analog inputs on pins you are not using. This makes the readings on the pins you do use, less accurate, as there is a tendency to pick up noise from other enabled pins through the multiplexer. Keep the number of enabled ADC pins to the minimum you need.
5) Your syntax for the ADC setup is wrong. The values need to be OR'ed together '|'. Currently you are selecting VSS_VDD, but not any channel (since in C, if multiple values are placed like this, it is the last one that is used).
6) Triple check you are connecting to the right pin. RA1, is pin 3.
7) to have any hope of actually 'learning' anything about the PIC, use real hardware, not Proteus. Proteus Isis, has the habit of allowing hardware combinations to be put together that will never work, and reporting that they do (hence the oscillator), and then of not working with combinations that are completely OK.
rikotech8
re
PostPosted: Tue May 08, 2012 3:29 am     Reply with quote
Thank you guys, for valuable information!
I have no tried the PIC real work yet, but when I do that, I'm going to tell you what happened.
rikotech8
PostPosted: Tue May 08, 2012 11:28 am     Reply with quote
You were right!
The problem was into the ISIS.
