12f1822 PWM basic question
vinniewryan
PostPosted: Sat May 05, 2012 4:28 pm     Reply with quote
I'm trying to set up a pwm output of roughly 38Khz and I'm just a little confused about how to set up timer2.
In the data sheet, it says to set up and enable timer2 in order to start the PWM output. I've configured the PWM so this should be the last step.
My question is, will setting up timer2 values have any effect on the PWM output speed? Can I just use the following:
   setup_timer2(T2_DIV_BY_1, 127, 1); //
   set_timer2(0); //reset/initiate the timer???
here's my code:
#include <12f1822.h>
#use delay(clock=32000000)
#Fuses INTRC_IO,NOWDT,NOPROTECT,NOMCLR
#byte APFCON = 0x01 //CCP on RA5
#byte PR2 = 0xD2 // PR2
#bit T2CON = 1.0 // prescaler is 1 (1)
#bit T2CON = 1.1 // prescaler is 1 (1)
#use rs232(xmit=pin_a4,baud=4800,invert)
   setup_oscillator(OSC_8MHZ | OSC_PLL_ON);
   setup_ccp1(CCP_PWM);                                        // Configure CCP1 as a PWM
   set_pwm1_duty (50);
   setup_timer_2(T2_DIV_BY_1, 127, 1); //
   set_tris_a    (0x2f);       //  101111  (0=output)      5 4 3 2 1 0
   PORT_a_PULLUPS(0x00);       //  000000  (1=enabled)     5 4 3 2 1 0
      //test pwm output
This is my first PWM attempt so don't be too harsh :P
Vinnie Ryan
PostPosted: Sat May 05, 2012 11:19 pm     Reply with quote
What's your compiler version ?
Mike Walne
PostPosted: Sun May 06, 2012 3:17 am     Reply with quote
Like PCM programmer says, read the forum guide and supply ALL the relevant information.
Generally speaking, your code
Will generate a PWM frequency given by:-
PWM frequency = ( Fosc / 4) / (mode * period )
In your case that's
32MHz / 4 / 1 / (127 + 1) = 62.5 kHz
So, the simple answer is yes. Timer2 setup does affect PWM frequency.
Mike
PostPosted: Sun May 06, 2012 3:44 am     Reply with quote
Also, remember that as well as affecting the speed, it'll affect the range of numbers useable for the duty cycle.
vinniewryan
PostPosted: Sun May 06, 2012 12:48 pm     Reply with quote
Perfect, thanks. Using your equation I figure 'mode' will need to be 210 in order to achieve as close to 38Khz as possible.
(32000000 / 4) / 1 / (210 + 1) = 37914.7
Vinnie Ryan
