exodia505
GLCD 122x32 |
Posted: Fri May 04, 2012 3:42 am |
hello !!
any working drivers for GLCD 122x32 ?plz
i use pic18f452
this is GLCD datasheet
LCD122x32-86903.pdf - 2.2 MB _________________ NOway!! |
ezflyr
Posted: Fri May 04, 2012 6:54 am |
A very short review of the datasheet indicates that the GLCD you posted uses the NUJ6450 LCD driver chip. A further very short Google search indicates that the NUJ6450 and the SED1520 LCD drivers are compatible. And finally, a very short forum search found a working SED1520 driver.
Was there anything else ?
John |
exodia505
Posted: Fri May 04, 2012 7:55 am |
Thanks ! where is that driver plz i tried one but didn't work
give me the driver plz _________________ NOway!! |
dyeatman
Posted: Fri May 04, 2012 1:11 pm |
Use forum search, put in SED1520 and you will find the driver. _________________ Google and Forum Search are some of your best tools!!!! |
exodia505
Posted: Fri May 04, 2012 1:39 pm |
hi, ofc i did that but i didn't get what i want ! _________________ NOway!! |
dyeatman
Posted: Fri May 04, 2012 2:11 pm |
OK, as was said earlier by ezflyer, a short search with Google and the second hit gives this:
http://geoffg.net/SG12232A_Driver.html _________________ Google and Forum Search are some of your best tools!!!! |
exodia505
Posted: Sat May 05, 2012 9:27 am |
Thanks for your help !
By the way, I said before in a comment that i tried a driver and didn't work
and unfortunately that one you gave me is what i was talking about.
Is there any driver compatible with graphics.c ? _________________ NOway!! |
exodia505
Posted: Sun May 06, 2012 11:23 am |
plz help!!! _________________ NOway!! |
dyeatman
Posted: Sun May 06, 2012 12:41 pm |
A check of the part number on the display confirms it is a standard SED1520
driver. Forget about graphics.c and use the last driver I pointed you to. It is
a known good driver. You likely have connection issues.
That display looks unused. Are you using real hardware or Proteus? _________________ Google and Forum Search are some of your best tools!!!! |
exodia505
Posted: Sun May 06, 2012 1:33 pm |
I usually start with simulation on Proteus then go to real hardware.
Why there is a CLK pin in that driver, I checked it on my LCD, doesn't exist ! _________________ NOway!! |
dyeatman
Posted: Sun May 06, 2012 5:23 pm |
If you are using Proteus I am unwilling to assist you further unless you
switch to real hardware. I don't do Proteus, too may bugs and
problems...sorry.
Maybe the Proteus forum can assist. I feel sure there are a number of
people over there that have used a GLCD and know about any bugs you
might encounter..
BTW, if your display doesn't need the clock then don't connect it. _________________ Google and Forum Search are some of your best tools!!!! |
exodia505
Posted: Mon May 07, 2012 8:24 am |
thanks for your help i apperciate it , in fact my real project was done on GLCD 128x64(ks0108)(its works greatfully on proteus menus+sub- menus and plotting signals,displaying bitmaps ...etc ) i didn't find it in market so i switched to 122x32
today i got Sg12864HSLb-GB-K03 GLCD and i'm going to use it !!
