RS232 is not working with PCD
kongfu1
PostPosted: Thu May 03, 2012 5:30 pm     Reply with quote
With PCD version 4.132 and PIC24EP512GU810, RS232 is not working and IOs are OK. See code below:
#include "24EP512GU810.h"
#fuses PR_PLL, NOIESO, NOWDT
#fuses XT, OSCIO
#use delay(clock=60M)
#pin_select U1TX=PIN_F5
#pin_select U1RX=PIN_F4
#use rs232(baud=9600, xmit=PIN_F5, rcv=PIN_F4,bits=8,parity=N,stop=1,stream = UART1)
    int i=0;
    printf("hello!!\r\n");
    for(;;)
        output_toggle(PIN_A0);
        output_toggle(PIN_A1);
        output_toggle(PIN_A2);
        output_toggle(PIN_A3);
        output_toggle(PIN_A4);
        output_toggle(PIN_A5);
        output_toggle(PIN_A6);
        output_toggle(PIN_A7);
        fprintf(UART1,"total counter=%d\r\n",i);
Please help.
Thanks,
Howard
PostPosted: Fri May 04, 2012 1:48 am     Reply with quote
You need to use:
#fuses XT, OSCIO
#use rs232(baud=9600, UART1,bits=8,parity=N,stop=1,stream = UART1)
Basically, you must _not_ put the pin numbers into the #USR RS232 declaration. Just 'UART1', which says 'talk to hardware UART1'. The select lines connect the pins to this UART.
Have you actually tested the system oscillates and is clocking at the right speed?. Two comments:
1) OSCIO - not legal with XT
2) Note2, Fig 9.1.
kongfu1
PostPosted: Fri May 04, 2012 10:26 am     Reply with quote
Ttelmah wrote:
You need to use:
#fuses XT, OSCIO
2) Note2, Fig 9.1.
Ttelmah,
Thanks for the help. I made changes:
#use rs232(baud=9600, bits=8,parity=N,stop=1,stream = UART1)
and removed OSCIO. There is no difference on the result.
Also, I have found out the clock is about 1.76 second instead of 1 second. It is much slower then specified. Do not know why.
PostPosted: Fri May 04, 2012 2:36 pm     Reply with quote
Start by telling it your oscillator frequency.....
How do you expect the code to know how to generate 60M, when you aren't telling it the crystal frequency?. Key is that it has to know what the XT crystal is running at to calculate the PLL divider. So you need (clock=yyy,crystal=xxx) so the calculation can be done.
kongfu1
PostPosted: Fri May 04, 2012 6:41 pm     Reply with quote
Internal RC was selected:
#fuses PR,FRC_PLL,NOWDT,ICSP1,NOJTAG
#device ADC=12
#use delay(clock=60M,internal)
It works OK now. Thanks.
