June Guest
What's wrong with my code? |
Posted: Wed Nov 20, 2002 9:38 pm |
Dear all,
The following codes is a PIC RS232 transmitter program. Every output will be delivered to another PIC and its own port B for display.
However the output of the program keep blinking after display from 0-15. What's wrong with my program? Please do me a favour. I need your help.
//program to transmit data
#include <16F876.h>
#fuses hs,noprotect,nowdt,nolvp
#byte PORTA=5
#byte PORTB=6
#byte PORTC=7
main()
int i;
set_tris_b(0); //set pin b0-b7 as output
do
for(i=0; i<16; i++)
putc(i);
portb=i;
delay_ms(2000);
}while(1);
Regards: June,
___________________________
Original Post ID: 9195 |
Mark
Re: What's wrong with my code? |
Posted: Thu Nov 21, 2002 12:56 am |
That is because your for loop is inside your do...while(1) so it will repeat over and over. The program below should only do 0-15 as you want
:=Dear all,
:= The following codes is a PIC RS232 transmitter program. Every output will be delivered to another PIC and its own port B for display.
:= However the output of the program keep blinking after display from 0-15. What's wrong with my program? Please do me a favour. I need your help.
:=//program to transmit data
:=#include <16F876.h>
:=#use delay(clock=20000000)
:=#fuses hs,noprotect,nowdt,nolvp
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=#byte PORTA=5
:=#byte PORTB=6
:=#byte PORTC=7
:=main()
:=int i;
:=set_tris_b(0); //set pin b0-b7 as output
:=delay_ms(1000);
for(i=0; i<16; i++)
putc(i);
portb=i;
delay_ms(2000);
:=Regards: June,
Original Post ID: 9201 |
June Guest
Posted: Thu Nov 21, 2002 2:40 am |
Thanks for your reply, I appreciate it much.
However if I want to design a program that can execute the following pattern:
1. Blink 0xFF for 1 times
2. Display 0-15
3. Blink 0xAA for 1 times
4. Go back to run step 1.
In this case can I write like following?
do
portb=0xff;
portb=0;
for(i=0; i<16; i++)
portb=i;
portb=0xaa;
portb=0;
}while(1);
Original Post ID: 9202 |
Mark
Posted: Thu Nov 21, 2002 6:53 am |
Yes, that is correct.
Regards,
mark
:=Thanks for your reply, I appreciate it much.
:=However if I want to design a program that can execute the following pattern:
:=1. Blink 0xFF for 1 times
:=2. Display 0-15
:=3. Blink 0xAA for 1 times
:=4. Go back to run step 1.
:=In this case can I write like following?
:=do
:=portb=0xff;
:=delay_ms(1000);
:=portb=0;
:=delay_ms(1000);
:=for(i=0; i<16; i++)
:= portb=i;
:= delay_ms(1000);
:=portb=0xaa;
:=delay_ms(1000);
:=portb=0;
:=delay_ms(1000);
:=}while(1);
Original Post ID: 9209 |
