set_pwm1_duty(temp) not working please help me ?
WAQASKHAN
PostPosted: Sat Apr 28, 2012 9:50 am     Reply with quote
#include <16f877a.h>
#device adc=10    // Set ADC resolution to 10Bit
#fuses XT,NOLVP,NOWDT,NOPROTECT
#use delay(clock=2000000)
#use rs232(baud=9600,bits=8,parity=N,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
#define  LOAD  PIN_B6
#define  THRES 40     // load switching threshold in Celsius
int16 digital_reading;  // ADC resolution is 10Bit, an 8Bit integer is not enough to hold the reading
float temp;
char value;
   /* ADC Initialization */
   setup_adc(ADC_CLOCK_INTERNAL); // initialize ADC with a sampling rate of Crystal/4 MHz
   setup_adc_ports(ALL_ANALOG);   // set PIN_A0 as analog input channel
   set_adc_channel(0);            // point ADC to channel 0 for ADC reading
   delay_ms(1);                   // ADC module is slow, needs some time to adjust.
   // set PWM
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 1023, 1);
   while(1) // infinite loop
      digital_reading = read_adc();    // capture current temperature reading
      delay_us(100);                   // 0.1ms delay for ADC stabilization
      temp = digital_reading * 0.4883; // convert reading to Celsius
      [color=red][b]set_pwm1_duty(temp);[/b[/color]]
      if(temp>=THRES)
      output_high(LOAD);   // Control Load
      output_low(LOAD);
      delay_ms(1000);   // 1 second delay between readings
      if(kbhit())
 value=getc();
 switch(value)
 case '1':
   output_high(pin_b0);
  case '2':
   output_high(pin_b1);
  case '3' :
   output_low(pin_b0);
  case '4' :
   output_low(pin_b1);
  case '5':
   printf("%lf\n",temp);
  default:
   printf("error");
WAQASKHAN
PostPosted: Sat Apr 28, 2012 9:53 am     Reply with quote
The Text in the Red is Actually set_pwm1_duty(temp)
PostPosted: Sat Apr 28, 2012 12:32 pm     Reply with quote
This may help:
http://www.ccsinfo.com/forum/viewtopic.php?t=43355
PostPosted: Sat Apr 28, 2012 1:57 pm     Reply with quote
What is the maximum value that Timer2's period can accept on a PIC16F877?. Read the manual entry.
