Disable Chip When Using Timer0 Interrupt in Pic18F97J60
tienchuan
PostPosted: Wed Apr 25, 2012 10:55 am     Reply with quote
Hi all
I have a problem: when I make declaration to use timer0 interrupt, my program not run, and when I test delete declaration of timer0, my program run correctly.
I'm using pic 18F97J60
And PCWH complier 4.078
Config fuses :
#fuses NOWDT,HS,NOPROTECT,NODEBUG
Setup timer0:
setup_timer_0( RTCC_INTERNAL);
set_timer0(0);
enable_interrupts(int_timer0);
Please show me way to solve this problem: )
Thanks and regards Smile
Begin Begin Begin !!!
bkamen
PostPosted: Wed Apr 25, 2012 2:14 pm     Reply with quote
You really need to show us a complete example.
I use the 97j60's fairly regularly and don't have the issue you're talking about.
Without seeing the rest, it's hard for me (or any of us) to help.
Post a short but compilable example please.
-Ben
p.s. You're running this on real hardware, right?
PostPosted: Wed Apr 25, 2012 2:48 pm     Reply with quote
Obvious thing that would hang the chip, is if you enable the interrupt, have already got the global level enabled, and haven't got a handler present. Instant crash....
tienchuan
PostPosted: Thu Apr 26, 2012 3:34 am     Reply with quote
Thanks Ttelmah and bkamen
My program only declares Timer0 interrupt and don't do anything in timer0 ISR, but when I declare Timer0, my program is not run ?
My program :
      TRISA=0;
      TRISB=0;
      TRISJ=0;
      TRISE=0;
      TRISD=0;
      TRISH=0;
      TRISG=0X04;//rs232
      TRISC=0X80;//rs232
      PORTJ=0;
      PORTE=0;
      PORTD=0;
      portb=0;
      set_timer0(0);
      //enable_interrupts(int_timer0);
      enable_interrupts(int_rda2);
      enable_interrupts(int_rda);
      enable_interrupts(global);
      lcd_putc("\f");
      lcd_gotoxy(1,1);
      printf(lcd_putc,"DO AN TOT NGHIEP");
      lcd_gotoxy(3,2);
      printf(lcd_putc,"DTVT-BKDN");
      delay_ms(3000);
      LCD_MoveLeft(20);
      lcd_putc("\f");
      lcd_gotoxy(3,1);
      printf(lcd_putc,"GPS Tracking");
      lcd_gotoxy(3,2);
      printf(lcd_putc,"H&C Solutions");
      delay_ms(2000);
      LCD_MoveRight(20);
      lcd_putc("\f");
      fputs("AT+CMGD=1",ID1);
      fputc(13,ID1);
      //fputs("AT+CDNSORIP=1\n",ID1);// da cau hinh tren sim               AT+CIPSCONT// luu cau hinh nay!
      //delay_ms(1000);
       portb=0;
       portb=0xff;
and here is my circuit:
[/img]
tienchuan
PostPosted: Mon Apr 30, 2012 8:59 am     Reply with quote
pls show me way to solve that problem ?
thnks
