TCPIP stack problem
stoyanoff
TCPIP stack problem
PostPosted: Wed Apr 25, 2012 10:25 am     Reply with quote
I'm using MPlab v8.33 and CCS complier v4.069. I have pic18F66J60 so I tried to redefine stack for this chip, because it wasn't in the ccstcpip.h. So I stopped all chip options in ccstcpip.h and I added to my main program this code:
#include <18F66J60.h>
#Fuses HS,NOWDT
#use delay(clock=25M)
#define STACK_USE_CCS_PICEEC 1
The compiler doesn't show any errors (it compiles it fine), but when I load this program to the controller nothing happens. I tried with simple program and the controller works. So I think my modification is the problem.
What must I do to use the tcpip stack with 18F66J60? What do I have to change and where??
Thanks!
stoyanoff
PostPosted: Wed May 02, 2012 1:07 am     Reply with quote
I tried with loading ex11.c from the examples in the stack. So as result I have the first 2 messages changing on the screen:
\fCCS TCP/IP Tut. and \nNo Ethernet. They are changing in around 0.5s.
Any ideas where to search for the problem???
Thanks!
jgschmidt
PostPosted: Wed May 02, 2012 11:34 am     Reply with quote
Did you create a definition for your hardware in CCSTCPIP.h and HARDWARE.h?
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=37139
for an example of how I added support for a new board.
Jürgen
www.jgscraft.com
stoyanoff
PostPosted: Sun May 13, 2012 6:50 am     Reply with quote
Hi, again!
I`ve made a simple change in the ccstcpip.h :
#elif STACK_USE_CCS_PICEEC
  #fuses NOWDT, NODEBUG, HS
and this:
 #define USER_LED1    PIN_A0
 #define USER_LED2    PIN_A1
 *0xF92=*0x00;
I`ve made a simple program using ex11.c
   MACAddrInit();
   *0xF92=*0x00;
   output_high(PIN_A0);
   output_high(PIN_A1);
   IPAddrInit();
   StackInit();
   StackTask();
But in this case the 2 leds must light continiously but they flash. I double check but the controller is not restarting. Is this a problem??
When I connect a switch to the pcb, it doesn`t show a new device connected, so I think the stack is not working, but ....
asmallri
PostPosted: Sun May 13, 2012 7:19 pm     Reply with quote
Try #use FAST_IO(A) - this will require you setting the port a TRIS settings manually.
Regards, Andrew
