70 MIPS & PIC24EP512GP806
cfernandez
PostPosted: Sun Apr 22, 2012 4:44 pm     Reply with quote
I want use the PIC24EP512GP806 in 70MIPS but I not found the right fuse configuration for this.
Is possible that anybody send me examples use the Internal Osc and External Osc.
Is very important for a new project.
I test this configuration:
#include <24EP512GP806.h>
#device *=16
#device adc=8
//#device PSV=16
//#device nested_interrupts=TRUE
#if __DEBUG__
    #device PASS_STRINGS=IN_RAM
#endif
#fuses PUT128                   // Power On Reset Timer value 128ms
#fuses WDT                      // Watch Dog Timer
#fuses WINDIS                   // Watch Dog Timer in non-Window mode
#fuses WPRES32                  // Watch Dog Timer PreScalar 1:32
#fuses WPOSTS15                 // Watch Dog Timer PostScalar 1:16384
//#define __INTERNAL_RC__
#ifdef __INTERNAL_RC__
    #fuses NOIESO                   // Internal External Switch Over mode disabled
    #fuses OSCIO                    // OSC2 is general purpose output
    #fuses FRC_PLL                  // Internal Fast RC oscillator with PLL
    #fuses CKSFSM                   // Clock Switching is enabled, fail Safe clock monitor is enabled
#else
    #fuses NOOSCIO                  // OSC2 is clock output
    #fuses XT                       // Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
    #fuses PR_PLL                   // Primary Oscillator with PLL
#endif
#fuses NOJTAG                     // JTAG disabled
//#fuses NORBS                    // No Boot RAM defined
//#fuses NORSS                    // No secure segment RAM
//#fuses NOSSS                    // No secure segment
//#fuses NOWRTSS                  // Secure segment not write protected
//#fuses PROTECT_HIGH             // General Segment Code Protect High Security
//#fuses NOWRT                    // Program memory not write protected
    #use delay( clock=120000000, type=INTERNAL, LOCK )
#else
    #use delay( clock=120000000, crystal=10000000, LOCK )
#endif
But if I put clock=140Mhz for obtain 70Mips the compiler send me a Error !!!
Thanks & Regards,
