RTCC alarm problem with PIC18F67k22
haseeb
PostPosted: Mon Apr 02, 2012 4:47 am     Reply with quote
Hello
I'm using PIC18F67K22 with internal OSC 4MHz and CCS compiler ver
4.130. I have the RTCC clock selection used with (SOSC0 & SOSC1)
via crystal 32.768kHz.
I have a simple test program where I set the alarm for 10secs
and then wait to see if my LED will flash after 10secs. The process
then repeats itself as per my program.
However, I can not achieve this since my LED is not flashing
at will with the RTCC alarm. On its own, the LED does flash and i can
even set the flashing rate to any rate that i desire.
Please can someone help and suggest where i'm wrong in my code
below and how to achieve RTCC alarm.
Haseeb
#include <18F67K22.h>
#fuses INTRC_IO, NOWDT, NOBROWNOUT, MCLR
// Set Speed to 4Mhz
#include <stdio.h>
int alarm_flag = 0;
#int_RTC
void RTC_isr(void)
   alarm_flag = 1; //raise flag once 10secs lapse
   delay_ms(500); //startup delay
   enable_interrupts(INT_RTC); //enable RTC interrupts
   setup_rtc(RTC_ENABLE); //enable RTC
   while(true) //loop forever
      setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_10_SECONDS, 0x08); //initiallize 10 sec alarm
      while(alarm_flag == 0); //stay here until 10sec alarm
      alarm_flag = 0; //reset flag
      //flash to indicate 10sec alarm
      output_high(pin_B4);
       delay_ms(200);
       output_low(pin_B4);
       delay_ms(200);
       delay_ms(200);
       output_low(pin_B4);
       delay_ms(200);
jeremiah
PostPosted: Mon Apr 02, 2012 5:00 am     Reply with quote
Try changing
enable_interrupts(GLOBAL); //enable interrupts
If it gives a compiler error, look in the .h file for which "global" define is correct.
haseeb
PostPosted: Mon Apr 02, 2012 5:11 am     Reply with quote
Hi
I have just done that and enabled GLOBAL interrupts as well.
Compiler gives NO error. But still my LED will not flash via
alarm....
please help...
Haseeb
haseeb
PostPosted: Mon Apr 02, 2012 5:57 am     Reply with quote
hello
anybody got any ideas regarding my alarm problem
haseeb
dyeatman
PostPosted: Mon Apr 02, 2012 6:25 am     Reply with quote
Haseeb, this is a user forum, not CCS, so everyone may not be looking at
the forum right now. It may take a while before someone with the specific
knowledge you need gets a chance to check in. You have to be patient. If
you let your project get down to the deadline that is your problem...not one
that we caused.
Google and Forum Search are some of your best tools!!!!
PostPosted: Mon Apr 02, 2012 8:41 am     Reply with quote
I don't see you enabling the secondary oscillator. This is needed for the RTC to run. SOSC_LOW, and RTCOSC_T1 in the fuses, and setup_timer_1(T1_ENABLE_SOSC); in the code
I think it is probably defaulting to T1, but this is not enabled, so it doesn't run.
The T1 setting controls whether the secondary oscillator runs or not.
haseeb
PostPosted: Tue Apr 03, 2012 9:05 am     Reply with quote
Hi
I have just tried your suggestion and still the RTC is not working.
No interrupt occur and my LED does not flash.
please help!
haseeb
jeremiah
PostPosted: Tue Apr 03, 2012 10:23 am     Reply with quote
Post your updated code (or just update the code in your first post and let us know), so we can see that changes got in there as it was suggested.
Gabriel
PostPosted: Tue Apr 03, 2012 12:38 pm     Reply with quote
Syntax...
take the Semi colon out, and add brackets.
 while(alarm_flag == 0){} //stay here until 10sec alarm
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Tue Apr 03, 2012 2:44 pm     Reply with quote
Syntax...
G.
This is not needed.
In C, an 'if', executes the single code block after the command.
A line terminated with ';' is a code block, as are multiple lines contained in '{}' braces.
The original is syntactically perfectly OK.
haseeb
PostPosted: Wed Apr 04, 2012 7:04 am     Reply with quote
ok thanks guys for your suggestions....
i will post the new updated code....now
haseeb
haseeb
PostPosted: Thu Apr 19, 2012 3:16 am     Reply with quote
Hello people
I have tried all that you have suggested and i have even tried out
the RTCC example program as below and it compiles and the output
is as below....HOWEVER....the clock does not seem to tick at all as the
seconds do not increment.
I have disabled the alarm and now its only the clock that i want to
get up and running.
Please can someone help....
Haseeb
OUTPUT on HyperTerminal as below....
Press ENTER after 1 digit answers.
Year 20: 12
Month: 04
Day: 19
Weekday 1-7: 05
Hour: 10
Min: 09
04/19/2012 10:09:00
//Internal RTCC....
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOPROTECT
#FUSES RTCOSC_T1
#FUSES SOSC_LOW
#FUSES MCLR
// RS232 to PC
#use rs232(baud=9600, UART1, STREAM=User)
#include <stdio.h>
int8 get_number()
  char first,second;
  do {
    first=fgetc(User);
  } while ((first<'0') || (first>'9'));
  fputc(first,User);
  first-='0';
  do {
    second=fgetc(User);
  } while (((second<'0') || (second>'9')) && (second!='\r'));
  fputc(second,User);
  if(second=='\r')
    return(first);
    return((first*10)+(second-'0'));
void set_clock(rtc_time_t &date_time)
   fprintf(User, "\r\nPress ENTER after 1 digit answers.");
   fprintf(User, "\r\nYear 20: ");
   date_time.tm_year=get_number();
   fprintf(User, "\r\nMonth: ");
   date_time.tm_mon=get_number();
   fprintf(User, "\r\nDay: ");
   date_time.tm_mday=get_number();
   fprintf(User, "\r\nWeekday 1-7: ");
   date_time.tm_wday=get_number();
   fprintf(User, "\r\nHour: ");
   date_time.tm_hour=get_number();
   fprintf(User, "\r\nMin: ");
   date_time.tm_min=get_number();
   date_time.tm_sec=0;
   printf("\r\n\n");
   //Initiallize All I/O Pins....
   //PORTA
   output_low(pin_A2);
   output_low(pin_A3);
   output_low(pin_A4);
   output_low(pin_A5);
   output_low(pin_A6);
   output_low(pin_A7);
   //PORTB
   output_low(pin_B1);
   output_low(pin_B2);
   output_low(pin_B3);
   output_low(pin_B5);
   //PORTC
   output_low(pin_C2);
   output_high(pin_C5);
   //PORTD
   output_d(0);
   //PORTE
   output_e(0);
   //PORTF
    output_low(pin_F1);
   output_low(pin_F2);
   output_low(pin_F3);
   output_low(pin_F4);
   output_low(pin_F5);
   output_low(pin_F6);
   output_low(pin_F7);
   //PORTG
    output_low(pin_G0);
   output_low(pin_G3);
   output_low(pin_G4);
   disable_interrupts(GLOBAL);
   delay_ms(100); //startup delay
   rtc_time_t write_clock, read_clock;
   setup_rtc(RTC_ENABLE,0);         //enables internal RTCC
   set_clock(write_clock);
   rtc_write(&write_clock);         //writes new clock setting to RTCC
   while(true)
      rtc_read(&read_clock);        //reads clock value from RTCC
      fprintf(User, "\r%02u/%02u/20%02u %02u:%02u:%02u",
      read_clock.tm_mon,
      read_clock.tm_mday,
      read_clock.tm_year,
      read_clock.tm_hour,
      read_clock.tm_min,
      read_clock.tm_sec);
      delay_ms(250);
haseeb
PostPosted: Fri Apr 20, 2012 6:25 am     Reply with quote
Hello People...
I have finally been able to get both the clock ticking and the alarm interrupts working as well. A change of crystal solved the problem.
However I can only get alarm interrupts for half second and one second only.
Please can you let me know why I cannot get higher delays with my alarm interrupts. Ideally I want this to be for 1 hour alarm setting.
But I tried to progress to that stage and found I could only do up to 1second complete.
Below is how I set the alarm configurations as per the PIC header fileā€¦
//setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_HALFSECOND, 0); //WORKS
//setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_SECOND, 0);     //WORKS
//setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_10_SECONDS, 0);   //DOES NOT WORK!!
   setup_rtc_alarm(RTC_ALARM_ENABLE, RTC_ALARM_10_MINUTES, 0);   //DOES NOT WORK!!
This clearly reflects a software issue.
Please can you look at my program below and kindly suggest.
haseeb
#FUSES INTRC_IO, NOWDT, SOSC_LOW, NOBROWNOUT, MCLR
#device ADC = 12
// RS232 to Modem
#use rs232(baud=9600, UART2, STREAM=Modem)
// RS232 to PC
#define Boost_Converter      pin_B5
#define LED               pin_B4
#define Emerg_RST_Modem     pin_C2
#define V285_Pin            pin_C3
#define V180_Pin            pin_C4
#define Modem_ON            pin_C5
#include <stdio.h>
char clock_sleeping = 1; //flag to tell us that we have woken up from ...
                   // ... sleeping when the alarm INT (0 = wakeup / 1 = sleep)
#int_RTC
void RTC_isr(void)
   //we have woken up from sleep
   clock_sleeping = 0;
//RTCC function
   //reseting the clock...
   date_time.tm_year=12;  //2012
   date_time.tm_mon=4;    //April
   date_time.tm_mday=20;  //20th
   date_time.tm_wday=6;     //Friday
   date_time.tm_hour=13;  //13hrs
   date_time.tm_min=8;     //8min
   date_time.tm_sec=0;    //0secs
   //PORTA
   output_low(pin_A2);
   output_low(pin_A3);
   output_low(pin_A4);
   output_low(pin_A5);
   output_low(pin_A6);
   output_low(pin_A7);
   //PORTB
   output_low(pin_B1);
   output_low(pin_B2);
   output_low(pin_B3);
   output_high(pin_B5);
   //PORTC
   output_low(pin_C2);
   //PORTD
   output_d(0);
   //PORTE
   output_e(0);
   //PORTF
    output_low(pin_F1);
   output_low(pin_F2);
   output_low(pin_F3);
   output_low(pin_F4);
   output_low(pin_F5);
   output_low(pin_F6);
   output_low(pin_F7);
   //PORTG
    output_low(pin_G0);
   output_low(pin_G3);
   output_low(pin_G4);
   //Clock Initiation Commands...
   //Print initial clock settings....
   fprintf(User, "\n\r\n\r %02u:%02u:%02u", read_clock.tm_hour, read_clock.tm_min, read_clock.tm_sec);
      //Before going to SLEEP .... set the Alarm!!!
      sleep(); //now goto sleep...
      delay_ms(100); //When waking up, delay needed to bring the PIC up to working state
      if(clock_sleeping == 0) //did we wake up from clock INT?
         clock_sleeping = 1; //set sleep flag to indicate that we are about to goto sleep again...
         delay_ms(100); //before we go back and set alarm...put delay as PIC likes it!
