EEPROM detection
DuncanH
EEPROM detection
PostPosted: Wed Nov 20, 2002 3:48 am     Reply with quote
How can I determine if a device has internal EEPROM within the preproccessor commands. I need to do a conditional compilation dependant on internal eeprom availability
___________________________
Original Post ID: 9133
R.J.Hamlett
Re: EEPROM detection
PostPosted: Wed Nov 20, 2002 5:10 am     Reply with quote
:=How can I determine if a device has internal EEPROM within the preproccessor commands. I need to do a conditional compilation dependant on internal eeprom availability
Why not just use the device numbers?.
Hence:
#if __device__==673 || __device==674
#define EEPROM_PRESENT
Then in the code:
#ifdef EEPROM_PRESENT
//Here the chip has an eeprom
Obviously you'd have to pick the chipnumbers to suit, mine are for the 12C67x family.
Original Post ID: 9135
DuncanH
PostPosted: Wed Nov 20, 2002 6:12 am     Reply with quote
:=:=How can I determine if a device has internal EEPROM within the preproccessor commands. I need to do a conditional compilation dependant on internal eeprom availability
:=Why not just use the device numbers?.
:=Hence:
:=#if __device__==673 || __device==674
:=#define EEPROM_PRESENT
:=#endif
:=Then in the code:
:=#ifdef EEPROM_PRESENT
:= //Here the chip has an eeprom
:=#endif
:=Obviously you'd have to pick the chipnumbers to suit, mine are for the 12C67x family.
:=Best Wishes
Can't do this as the 18c452 and 18f452 both have the same device number but one has eeprom and the other doesn't
Original Post ID: 9136
R.J.Hamlett
PostPosted: Wed Nov 20, 2002 7:04 am     Reply with quote
:=:=:=How can I determine if a device has internal EEPROM within the preproccessor commands. I need to do a conditional compilation dependant on internal eeprom availability
:=:=Why not just use the device numbers?.
:=:=Hence:
:=:=#if __device__==673 || __device==674
:=:=#define EEPROM_PRESENT
:=:=#endif
:=:=Then in the code:
:=:=#ifdef EEPROM_PRESENT
:=:= //Here the chip has an eeprom
:=:=#endif
:=:=Obviously you'd have to pick the chipnumbers to suit, mine are for the 12C67x family.
:=:=Best Wishes
:=Can't do this as the 18c452 and 18f452 both have the same device number but one has eeprom and the other doesn't
Check for the presence of the 'INT_EEPROM' variable. On these more sophisticated chips, this is defined if this interrupt exists. So:
#ifdef INT_EEPROM
//Here the chip has an EEPROM
#else
//Here the chip does not.
It is actually easier on these chips, than on the simpler ones. :-)
Original Post ID: 9137
Woody
PostPosted: Wed Nov 20, 2002 7:27 am     Reply with quote
Another possibility may be to use the built in function getenv() to retrieve the EEPROM size at compile time.
#include <16c452.h>
#define EEPROM_PRESENT (getenv("DATA_EEPROM") > 0)
void main (void)
if (EEPROM_PRESENT) {
Original Post ID: 9142
Felix Althaus
Re: EEPROM detection getenv?
PostPosted: Wed Nov 20, 2002 1:00 pm     Reply with quote
:=#define EEPROM_PRESENT (getenv("DATA_EEPROM") > 0)
This getenv() interests me. Are there more env variables? If yes is there a documentation? Is the getenv limited to a certain compiler version?
Felix
Original Post ID: 9167
R.J.Hamlett
PostPosted: Wed Nov 20, 2002 3:22 pm     Reply with quote
:=:=#define EEPROM_PRESENT (getenv("DATA_EEPROM") > 0)
:=This getenv() interests me. Are there more env variables? If yes is there a documentation? Is the getenv limited to a certain compiler version?
:=Thanks
Yes.
It is relatively new, and the documentation doesn't exist in the 'help' file, but in the 'readme', for the last few versions. Typically I had forgotten it in suggesting using the INT_EEPROM variable.
This is copied from the readme:
The built in function getenv() has been added. The syntax is
value = getenv(cstring);
cstring is a constant string with a recognised keyword
as follows:
FUSE_SET:fffff Returns 1 if fuse fffff is enabled
FUSE_VALID:fffff Returns 1 if fuse fffff is valid
INT:iiiii Returns 1 if the interrupt iiiii is valid
ID Returns the device ID (set by #ID)
DEVICE Returns the device name string (like "PIC16C74")
CLOCK Returns the Osc clock value (from a #USE DELAY)
VERSION Returns the compiler version as a float
VERSION_STRING Returns the compiler version as a string
PROGRAM_MEMORY Returns the size of memory for code (in words)
STACK Returns the stack size
DATA_EEPROM Returns the number of bytes of data EERPOM
READ_PROGRAM Returns a 1 if the code memory can be read
PIN:pb Returns a 1 if bit b on port p is on this part
ADC_CHANNELS Returns the number of A/D channels
ADC_RESOULTION Returns the number of bits returned from READ_ADC()
ICD Returns a 1 if this is being compiled for a ICD
SPI Returns a 1 if the device has SPI
USB Returns a 1 if the device has USB
CAN Returns a 1 if the device has CAN
I2C_SLAVE Returns a 1 if the device has I2C slave H/W
I2C_MASTER Returns a 1 if the device has I2C master H/W
PSP Returns a 1 if the device has PSP
COMP Returns a 1 if the device has a comparator
VREF Returns a 1 if the device has a voltage reference
LCD Returns a 1 if the device has direct LCD H/W
UART Returns the number of H/W UARTs
CCPx Returns a 1 if the device has CCP number x
TIMERx Returns a 1 if the device has TIMER number x
Examples:
#IF getenv("VERSION")<3.050
#ERROR Compiler version too old for this program
#ENDIF
for(i=0;i write_eeprom(i,0);
#IF getenv("FUSE_VALID:BROWNOUT")
#FUSE BROWNOUT
#ENDIF
It is very useful, since it allows conditional compilation on most chip abilities. :-)
3.074, doesn't list it, but 3.099 does. Hence it must date from somewhere between these two versions.
Original Post ID: 9177
DuncanH
PostPosted: Mon Nov 25, 2002 5:19 am     Reply with quote
:=:=:=#define EEPROM_PRESENT (getenv("DATA_EEPROM") > 0)
:=:=This getenv() interests me. Are there more env variables? If yes is there a documentation? Is the getenv limited to a certain compiler version?
:=:=Thanks
:=Yes.
:=It is relatively new, and the documentation doesn't exist in the 'help' file, but in the 'readme', for the last few versions. Typically I had forgotten it in suggesting using the INT_EEPROM variable.
:=This is copied from the readme:
:=The built in function getenv() has been added. The syntax is
:= value = getenv(cstring);
:= cstring is a constant string with a recognised keyword
:= as follows:
:= FUSE_SET:fffff Returns 1 if fuse fffff is enabled
:= FUSE_VALID:fffff Returns 1 if fuse fffff is valid
:= INT:iiiii Returns 1 if the interrupt iiiii is valid
:= ID Returns the device ID (set by #ID)
:= DEVICE Returns the device name string (like "PIC16C74")
:= CLOCK Returns the Osc clock value (from a #USE DELAY)
:= VERSION Returns the compiler version as a float
:= VERSION_STRING Returns the compiler version as a string
:= PROGRAM_MEMORY Returns the size of memory for code (in words)
:= STACK Returns the stack size
:= DATA_EEPROM Returns the number of bytes of data EERPOM
:= READ_PROGRAM Returns a 1 if the code memory can be read
:= PIN:pb Returns a 1 if bit b on port p is on this part
:= ADC_CHANNELS Returns the number of A/D channels
:= ADC_RESOULTION Returns the number of bits returned from READ_ADC()
:= ICD Returns a 1 if this is being compiled for a ICD
:= SPI Returns a 1 if the device has SPI
:= USB Returns a 1 if the device has USB
:= CAN Returns a 1 if the device has CAN
:= I2C_SLAVE Returns a 1 if the device has I2C slave H/W
:= I2C_MASTER Returns a 1 if the device has I2C master H/W
:= PSP Returns a 1 if the device has PSP
:= COMP Returns a 1 if the device has a comparator
:= VREF Returns a 1 if the device has a voltage reference
:= LCD Returns a 1 if the device has direct LCD H/W
:= UART Returns the number of H/W UARTs
:= CCPx Returns a 1 if the device has CCP number x
:= TIMERx Returns a 1 if the device has TIMER number x
:= Examples:
:= #IF getenv("VERSION")<3.050
:= #ERROR Compiler version too old for this program
:= #ENDIF
:= for(i=0;i := write_eeprom(i,0);
:= #IF getenv("FUSE_VALID:BROWNOUT")
:= #FUSE BROWNOUT
:= #ENDIF
:=It is very useful, since it allows conditional compilation on most chip abilities. :-)
:=3.074, doesn't list it, but 3.099 does. Hence it must date from somewhere between these two versions.
Thankyou all for you help. That seems to cure the problem
Original Post ID: 9379
