Andrew Welch Guest
PWM Question |
Posted: Mon Feb 10, 2003 12:09 am |
I want to use CCP1 in PWM mode to generate a 38khz pulse on an IR emitter. I'm using a 20mhz 16F877.
Is this possible? If so, what is the set up code? I'm having a hard time figuring that out.
Thanks...
___________________________
Original Post ID: 11465 |
Re: PWM Question |
Posted: Mon Feb 10, 2003 1:15 pm |
:=I want to use CCP1 in PWM mode to generate a 38khz pulse on an IR emitter. I'm using a 20mhz 16F877.
:=Is this possible? If so, what is the set up code? I'm having a hard time figuring that out.
Try this:
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=20000000)
// #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
main()
output_low(PIN_C1);
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1, 130, 1); // 38 KHz
set_pwm1_duty(65); // 50\% duty cycle
Original Post ID: 11482 |
Neutone
Re: PWM Question |
Posted: Mon Feb 10, 2003 2:42 pm |
:=:=I want to use CCP1 in PWM mode to generate a 38khz pulse on an IR emitter. I'm using a 20mhz 16F877.
:=:=Is this possible? If so, what is the set up code? I'm having a hard time figuring that out.
:=Try this:
:=#include "c:\program files\picc\devices\16F877.h"
:=#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
:=#use Delay(clock=20000000)
:=// #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
:=main()
:=output_low(PIN_C1);
:=setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
:=while(1)
:=setup_timer_2(T2_DIV_BY_1, 130, 1); // 38 KHz
:=set_pwm1_duty(65); // 50\% duty cycle
:=while(1);
Do you want to use a PWM frequency that is 16 times the bit time? The part I use does.
<a href="http://www-s.ti.com/sc/ds/tir1000.pdf" TARGET="_blank">http://www-s.ti.com/sc/ds/tir1000.pdf</a>
bit time 1/(9600)
PWM would be 1/(9600*16)
or 153.6 KHz
bit time 1/(2400)
PWM would be 1/(2400*16)
or 38.4 KHz
It would also help to use a crystal that makes your baud rate and iRDA clocl without errors.
#define XTAL_FREQUENCY 19660800
#use delay(clock=XTAL_FREQUENCY)
Original Post ID: 11485 |
Andrew Welch Guest
Re: PWM Question |
Posted: Mon Feb 10, 2003 9:32 pm |
:=Try this:
:=main()
:=while(1)
:=while(1);
Thanks very much! I'll give it a try. I wasn't sure of the right parameters for setup_timer.
Original Post ID: 11504 |
