18f4550 usb weird problem
sresam89
PostPosted: Tue Apr 03, 2012 2:40 am     Reply with quote
hello all
I am trying to implement ex_usb_serial.c in ccs examples with 18f4550. The code compiles and works very fine till enumeration, then n there stops
The driver supplied doesn't get installed. After a deep search i found the device parameters supplied and detected varies which aries the driver incompatibility.
the detected device class GUID(from devicemanager)
{36fc9e60-c465-11cf-8056-444553540000}
supplied(in driver)
{4D36E978-E325-11CE-BFC1-08002BE10318}
class detected(from device manager)
USB
supplied(in driver)3
ports
compiler 4.09
How am i supposed to correct these errors and make my driver install?
also
When i replace the class guid in the driver with that of device manager the driver detects the the device shows "USB TO UART" but doesn't start, puts up some error code.
matheuslps
PostPosted: Tue Apr 03, 2012 2:33 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=44917&p=142164
bye
