LCD driver
vasanthan
LCD driver
PostPosted: Tue Apr 03, 2012 6:30 am     Reply with quote
I am using PIC 16F887 and CCS-C compiler(version 4.093) plugin in MPLAB IDE. I've connected LCD to port D and it is working. I am using LCD.C driver to implement lcd functions in which LCD is configured as port access. Now i want to use pin 5 of port d for PWM (half bridge mode) which is already being used as LCD data pin. How do I change LCD data pin in driver ? What changes should I make in LCD.C in order to use pin D5 for PWM or to configure LCD using pin access ? I am not using pin D3. If I could use pin D3 for lcd data, can I use pin D5 for pwm ? How to do this ? I've attached LCD driver file and my code.
hardware connection details
port D
pin d0 connected to LCD enable
pin d1 connected to LCD RS
pin d2 connected to LCD R/W
pin d3 NOT USED
pin d4 connected to LCD data pin 4
pin d5 connected to LCD data pin 5
pin d6 connected to LCD data pin 6
pin d7 connected to LCD data pin 7
[b]LCD driver[/b]
////                             LCD.C                                     ////
////                 Driver for common LCD modules                         ////
Driver code deleted.
CCS lcd driver code removed.
Reason: Forum rule #10:
10. Don't post the CCS example code or drivers.
Forum rules -
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
#include <16f887.h>
#device ADC=10
#use delay(clock=16000000)
#fuses HS, NOWDT, NOPROTECT, NOLVP
#use RS232(baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#include <lcd.c>
       int16 temp_adc1;
       float temp1;
       int16 temp_adc2;
       float temp2;
       int16 volt_adc1;
       float volt1;
       int16 volt_adc2;
       float volt2;
       int16 crnt_adc1;
       float crnt1;
       int16 crnt_adc2;
       float crnt2;
       long pwmv_adc1;
 lcd_init();
 setup_adc(ADC_CLOCK_DIV_32);
        printf ( lcd_putc, "Battery Status\n" );
        delay_ms(100);                            //print to lcd  --- clear LCD ---  lcd_putc("\f");
        printf ("Battery Status vasanth\n\r" );  //print to serial com
        //temperature measurement
         set_adc_channel(0); //read analog input from channel 0
         delay_ms(10);
         temp_adc1 = read_adc();
         temp1 = 5.00*temp_adc1*100.00/1023.00; // = temp_adc*0.48828125;
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)temp1);
         delay_ms (100);                   // printf(lcd_putc, "value = %lu \n",value);
         lcd_putc(223);                     //this number 223 will display the degree sign
         delay_ms (100);
         lcd_putc('C');
         delay_ms (10);
         lcd_putc("  b1_temp");
         printf ("\n");
         delay_ms (100);
         printf ("%5.1f", (float)temp1);
         delay_ms (100);
         putc(223);
         putc('C');
         delay_ms (100);
         puts("  b1_temp");
         delay_ms (10);
         printf ("\n\r");
         set_adc_channel(1); //read analog input from channel 1
         delay_ms(10);
         temp_adc2 = read_adc();
         temp2 = temp_adc2*0.48828125;
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)temp2);
         delay_ms (100);
         delay_ms (100);
         lcd_putc('C');
         delay_ms (100);
         lcd_putc("  b2_temp");
         printf ("%5.1f", (float)temp2);
         delay_ms (100);
         putc(223);
         putc('C');
         delay_ms (100);
         puts("  b2_temp");
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);
        //voltage measrement
         set_adc_channel(2); //read analog input from channel 2
         delay_ms(10);
         volt_adc1 = read_adc();
         volt1 = (volt_adc1*0.0048875855)+9;//(volt*5)/1023
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)volt1);
         delay_ms (100);
         lcd_putc('V');
         delay_ms (100);
         lcd_putc("  b1_volt");
         printf ("%5.1f", (float)volt1);
         delay_ms (100);
         putc('V');
         delay_ms (100);
         puts("  b1_volt");
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);
         if(volt1<=10.5)
         output_high(PIN_B2);
         output_low(PIN_B2);
         set_adc_channel(5); //read analog input from channel 5
         delay_ms(10);
         volt_adc2 = read_adc();
         volt2 = (volt_adc2*0.0048875855)+9;//(volt*5)/1023
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)volt2);
         delay_ms (100);
         lcd_putc('V');
         delay_ms (100);
         lcd_putc("  b2_volt");
         printf ("%5.1f", (float)volt2);
         delay_ms (100);
         putc('V');
         delay_ms (100);
         puts("  b2_volt");
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);
         if(volt2<=10.5)
         output_high(PIN_B3);
         output_low(PIN_B3);
        // current measurement
         set_adc_channel(3); //read analog input from channel 3
         delay_ms(10);
         crnt_adc1 = read_adc();
         crnt1 = crnt_adc1*0.0048875855;//(volt*5)/1023
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)crnt1);
         delay_ms (100);
         lcd_putc('A');
         delay_ms (100);
         lcd_putc("  b1_crnt");
         printf ("%5.1f", (float)crnt1);
         delay_ms (100);
         putc('A');
         delay_ms (100);
         puts("  b1_crnt");
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);
         set_adc_channel(6); //read analog input from channel 6
         delay_ms(10);
         crnt_adc2 = read_adc();
         crnt2 = crnt_adc2*0.0048875855;//(volt*5)/1023
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"%5.1f", (float)crnt2);
         delay_ms (100);
         lcd_putc('A');
         delay_ms (100);
         lcd_putc("  b2_crnt");
         printf ("%5.1f", (float)crnt2);
         delay_ms (100);
         putc('A');
         delay_ms (100);
         puts("  b2_crnt");
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);
        //pwm value
       /*set_adc_channel(4); //read analog input from channel 4
         delay_ms(10);
         set_tris_c(0xff);
         pwmv_adc1 = read_adc();
         lcd_gotoxy(1,2);
         printf ( lcd_putc,"pwm_v= %lu",pwmv_adc1);// or set adc=8 and get using %x for int8 pwmv_adc1
         setup_ccp1(CCP_PWM);
         setup_timer_2(T2_DIV_BY_4,255,16);
         set_tris_c(0x00);
         set_pwm1_duty(pwmv_adc1);  //Change the duty cycle
         printf ("  pwm_v = %lu",pwmv_adc1);
         delay_ms (100);
         printf ("\n\r");
         delay_ms(50);*/
PostPosted: Tue Apr 03, 2012 6:56 am     Reply with quote
quickest,easiest solution...
..download the 'flex_lcd' driver from the code library...
It allows you to setup almost any PIC I/O pin for LCD use.
Mike Walne
LCD driver
PostPosted: Tue Apr 03, 2012 8:23 am     Reply with quote
Or you could configure LCD bits as:-
pin d0 connected to LCD data pin 4
pin d1 connected to LCD data pin 5
pin d2 connected to LCD data pin 6
pin d3 connected to LCD data pin 7
pin d4 connected to LCD enable
pin d5 NOT USED
pin d6 connected to LCD RS
pin d7 connected to LCD R/W
You've now made d5 free for the pwm, and you're keeping the data pins together as a nibble.
You'll should only have to change the structure definition, pin I/O maps, and code where you handle data.
Mike
PostPosted: Tue Apr 03, 2012 4:07 pm     Reply with quote
lcd_init();
You left out the line for setup_adc_ports(). You need it, so you can
specify which i/o pin should be enabled for Analog Input. Look in the
16F887.h file for a list of suitable parameters (sAN0, sAN1, etc.).
