18F26K22 with spi and I2c
cwedgwood
PostPosted: Mon Mar 26, 2012 9:11 am     Reply with quote
Does anyone have working code for this chip with both spi and I2C working?
My config is spi_2 and I2c on 1.
It seem to hang on any write to the I2C.
Thanks for any help.
Chris
PostPosted: Mon Mar 26, 2012 9:15 am     Reply with quote
Show us your code! A small,compilable program that has the problem.
also include compiler version and what value the I2C pullups re and bus speed.
We need more information to help you.
cwedgwood
PostPosted: Mon Mar 26, 2012 9:17 am     Reply with quote
Thanks,
No pullups, i'm using NOFLOAT_HIGH instead.
PostPosted: Mon Mar 26, 2012 9:41 am     Reply with quote
I2C devices need the correct pullups, it's in the specs
PostPosted: Mon Mar 26, 2012 9:44 am     Reply with quote
Seriously get rid of this, and add resistors.
NOFLOAT_HIGH, can _only_ be used with slave devices that do not use NACK to mark the last transfer. It is _not_ compatible with normal I2C operation.
cwedgwood
PostPosted: Mon Mar 26, 2012 9:50 am     Reply with quote
Thanks, but would this cause the code to hang?
PostPosted: Mon Mar 26, 2012 10:48 am     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=40930
cwedgwood
PostPosted: Wed Mar 28, 2012 3:14 am     Reply with quote
Thanks PCM, problem all fixed now.
