PWM OMG
dezso
PWM OMG
PostPosted: Sat Mar 24, 2012 1:52 am     Reply with quote
PIC16F877A
4.128 no IDE
20Mhz Clock
Turned to CCS again since my ASM code went sideways, after days of coding and close to 1000 line realized my approach is somewhat incorrect, just to blow some steam fired up CCS to play with it.
Now I been playing with C and C# for a few years but isn't my strongest tool, so don't byte my head off.
Below a simple code to Blink a LED on PortD and run PWM on CCP1 at 78.125Khz 25% duty.
Its not working ! LED blink about 2,3x than stops, PWM continue to run, went back to MC asm and create sample project with same values, I'm not including here the full asm just my timer and CCP setup, technically the rest of the asm is plain port setup and delay routine.
Why is this C code will stop executing the while(true) part after 1-2sec later !?
Maybe I'm just to stressed out and can't see the tree from the forest.
#include <main.h>
#define   LED      PIN_D0
   setup_ccp1(CCP_PWM);
   set_pwm1_duty((int16)63);
      setup_timer_2(T2_DIV_BY_1,63,1);      //12.8 us overflow, 12.8 us interrupt
   while(true)
      output_toggle(LED);
      delay_ms(250);
//INIT_PWM
//              BANKSEL    PR2
//              MOVLW      0X3F            // PWM period 78.125khz
//              MOVWF      PR2
//              MOVLW      B'00000100'         // Setup Timer2
//                  //0               // Unimplemented
//                  //-0000            // 1:1 postscale
//                  //-----1            // TMR2ON
//                  //------00         // Prescaler is 1
//              MOVWF      T2CON
//              BANKSEL    CCPR1L
//              MOVLW      B'00000111'         // Load 25% Duty 255/100*25=63.xx
//              MOVWF      CCPR1L            // MSB loaded to CCPR1L
//              BANKSEL    CCP1CON         // LSB  loaded to CCP1CON 5:4 bit
//              MOVLW      B'00111100'
//                  //00            // Unimplemented
//                  //--11            // LSB of Duty
//                  //----11xx         // PWM mode
//              MOVWF      CCP1CON
//              BSF         T2CON, TMR2ON      // Timer2 ON
//              RETURN
Question Arrow Question
I'm could be wrong many time's, at least I know what I'm doing Smile
gpsmikey
PostPosted: Sat Mar 24, 2012 9:27 am     Reply with quote
The first thing that comes to mind when you say it works a few times then quits is are there any interrupts running etc (you indicate this is only part of the code) ? When I have run into something like this in the past it was due to "clever" use of the stack where I was pushing something on it then forgetting to get it back and managing to crash the stack. Maybe after I have my coffee something will become more obvious to me, but that was the first thing that came to mind. (This does have the feel of one of those "duh" moments when you solve it though Laughing -- I have them on a regular basis myself )
mikey
PostPosted: Sat Mar 24, 2012 4:45 pm     Reply with quote
Always post the complete test program. Post the code in main.h.
You could have the LVP fuse set. Then that pin might float to a high level
and the PIC would go into LVP programming mode and lock up.
Or maybe you're missing the MCLR pull-up resistor, so that pin floats low
and locks up the PIC.
Or maybe you left off the series resistor on the LED and then the PIC's
pin driver circuit (or the whole PIC) has a problem.
I don't know. You didn't give enough information.
dezso
PostPosted: Sat Mar 24, 2012 5:31 pm     Reply with quote
this is beyond me...
This is the generated asm from the c code, it will compile and has the same result, led will stop flashing after 2,3 flash later.
It does not use any call so the stock stays at 0 level.
In the debugger if found that the line XORWF 0x8, F will not toggle the portd pin0, the W have value of 1 and bank switched back to 0, but it will toggle other registers if I change it to
MCLR is pulled up with 6.8k "thats what I pulled out from the box first !, It works with the ASM code just fine.
;---  C:\Documents and Settings\DevXP\My Documents\MPLAB8Project\10WattLEDC\main.c  ---------------
;1:                 #include <main.h>
org   0x00
      MOVLW 0
      MOVWF 0xa
      GOTO 0x1a
      NOP
;2:                 #define   LED      PIN_D0
;3:
;4:                 void main()
;5:                 {
org   0x1a
      CLRF 0x4
      BCF 0x3, 0x7
      MOVLW 0x1f
      ANDWF 0x3, F
      MOVLW 0x40
      BSF 0x3, 0x5
      MOVWF 0x19
      MOVLW 0xa6
      MOVWF 0x18
      MOVLW 0x90
      BCF 0x3, 0x5
      MOVWF 0x18
      MOVLW 0xff
      MOVWF 0x20
      BSF 0x3, 0x5
      BSF 0x1f, 0
      BSF 0x1f, 0x1
      BSF 0x1f, 0x2
      BCF 0x1f, 0x3
      MOVLW 0x7
      MOVWF 0x1c
;6:                    setup_ccp1(CCP_PWM);
      BCF 0x3, 0x5
      BCF 0x20, 0x2
      MOVF 0x20, W
      BSF 0x3, 0x5
      MOVWF 0x7
      BCF 0x3, 0x5
      BCF 0x7, 0x2
      MOVLW 0xc
      MOVWF 0x17
;7:                    set_pwm1_duty((int16)63);
      MOVLW 0xf
      MOVWF 0x15
      MOVF 0x17, W
      ANDLW 0xcf
      IORLW 0x30
      MOVWF 0x17
;8:                       setup_timer_2(T2_DIV_BY_1,63,1);      //12.8 us overflow, 12.8 us interrupt
      MOVLW 0
      MOVWF 0x78
      IORLW 0x4
      MOVWF 0x12
      MOVLW 0x3f
      BSF 0x3, 0x5
      MOVWF 0x12
;9:                    while(true)
;10:                   {
;11:                      output_toggle(LED);
      BCF 0x8, 0
      MOVLW 0x1
      BCF 0x3, 0x5   ;0x3
      XORWF 0x8, F
;12:                      delay_ms(250);
      MOVLW 0xfa
      MOVWF 0x21
      GOTO 0x4
;13:                   }
      BSF 0x3, 0x5
      GOTO 0x45
      SLEEP
;---  C:\Documents and Settings\DevXP\My Documents\MPLAB8Project;;\10WattLEDC\main.h  ---------------
;1:                 #include <16F877A.h>
;2:                 #device adc=8
;3:                 #FUSES NOWDT                    //No Watch Dog Timer
;4:                #FUSES HS                       //High speed Osc (> 4mhz ;for PCM/PCH) (>10mhz for PCD)
;5:                #FUSES NOPUT                    //No Power Up Timer
;6:                #FUSES NOBROWNOUT               //No brownout reset
;7:                #FUSES NOLVP                    //No low voltage prgming, ;B3(PIC16) or B5(PIC18) used for I/O
;8:
;9:                #use delay(clock=20000000)
org   0x04
      MOVLW 0x21
      MOVWF 0x4
      BCF 0x3, 0x7
      MOVF 0, W
      BTFSC 0x3, 0x2
      GOTO 0x17
      MOVLW 0x6
      MOVWF 0x78
      CLRF 0x77
      DECFSZ 0x77, F
      GOTO 0xd
      DECFSZ 0x78, F
      GOTO 0xc
      MOVLW 0x7b
      MOVWF 0x77
      DECFSZ 0x77, F
      GOTO 0x13
      DECFSZ 0, F
      GOTO 0xa
      BCF 0xa, 0x3
      BCF 0xa, 0x4
      GOTO 0x4c
end
Shocked Shocked Shocked
dezso
PostPosted: Sat Mar 24, 2012 8:35 pm     Reply with quote
ok found the problem and now it is working, wasn't a compile or code problem, it was working as it should be.
The problem was that I connected the led to the PORTD pin0 wo any resistor, the code simply was trying to XOR the state of the pin, doing this by reading the pin and could not read as high since was loaded by the LED.
Adding a 470ohm fixed the problem, on port B or C it wouldn't be a problem, that was a interesting experiment tho..
PostPosted: Sat Mar 24, 2012 9:14 pm     Reply with quote
You should always use a series resistor with an LED. It's standard
engineering design practice. It limits the current to be within the
specified range, so as not to exceed the limits for the LED or the
pin driver on the PIC.
dezso
PostPosted: Sun Mar 25, 2012 12:13 am     Reply with quote
There was no design in place, this has nothing to do with the project I'm working on, LED was added for debugging purpose only and wasn't thinking on the portD architecture. When I noticed that the port not toggling than I start a new project to investigate why.
Thanks anyway.
Arrow
