Code fails to compile post MPLAB install
steve_smith94
PostPosted: Wed Mar 21, 2012 6:26 am     Reply with quote
I'm pretty stuck here. I have some code that compiled in CCS PCW v4.124 this morning. I then needed to program my hardware.
Previously I used MPLAB to program earlier versions. However, I have recently installed windows 7 on my machine and had to re-install MPLAB.
The install went ok, but now the code will not compile. Even the earlier version (that programmed ok and the unit worked to spec) fails in the same manner:
Error 128 "MyPath\16F917.h" Line 204(2,6): A #Device required before this line.
Anyone know why installing MPLAB caused this? Confused
Cheers,
Steve
RF_Developer
PostPosted: Wed Mar 21, 2012 7:31 am     Reply with quote
Maybe, are you on a 64bit version of seven?
The problem is that the driver and device search paths need to change. They used to be somewhere in Program Files, they are now in Program Files (x86) and so the compiler cannot find the device include files. So you need to check your project's search paths.
RF Developer
