warp13a ,12f675 and mplab
dave.t
PostPosted: Mon Nov 18, 2002 4:35 am     Reply with quote
Hi all,
I am having trouble getting my Warp13a (Redback 10a) programmer to work with mplab when using the 12f675.
The problem is when I enable the Picstart Plus programmer,when running Mplab,and select 12f675 it tells me i need to upgrade Picstart Plus. Mplab regards the Warp13a programmer as a Picstart Plus - I have upgraded my Warp13a to Redback 10a so it will program the 12f675 - so why will it not work in Mplab?
Many thanks.
___________________________
Original Post ID: 9048
john cutler
Re: warp13a ,12f675 and mplab
PostPosted: Mon Nov 18, 2002 10:42 am     Reply with quote
:=Hi all,
:=I am having trouble getting my Warp13a (Redback 10a) programmer to work with mplab when using the 12f675.
:=The problem is when I enable the Picstart Plus programmer,when running Mplab,and select 12f675 it tells me i need to upgrade Picstart Plus. Mplab regards the Warp13a programmer as a Picstart Plus - I have upgraded my Warp13a to Redback 10a so it will program the 12f675 - so why will it not work in Mplab?
:=Many thanks.
I have the same problem - an unforturnately no cure. Since I got PCWH from CCS, I can launch the Warp13 software from the toolbar and program the PIC, but when I use MPLab, same problem as you. I hope someone has the answer!
John
Original Post ID: 9064
