john lee Guest
Bresenham algorithm in a Pic 16c73A |
Posted: Fri Nov 15, 2002 12:37 pm |
Hi, I have been using Pics for a few years now, has anyone written a useable interpretation of Jack Bresenham''s line algorithm for a Pic?I am using a 16c73a to drive a multi-axis machine, i.e to generate speed-ramped pulse trains in order to provide synchronised point-to-point moves, using a velocity profile.The move is not trapezoidal, but uses s-ramps to avoid the otherwise instantaneous torque foldback/windup at the turning-points. I am having problems with the interrupt latency.
System works, but, one of u has probably done it better!
Any contributions most welcome.
Regards,
Stigga the dump.
___________________________
Original Post ID: 9015 |
Doug Kennedy Guest
Re: Bresenham algorithm in a Pic 16c73A |
Posted: Fri Nov 15, 2002 1:52 pm |
This will draw a line between cartesian pts (x1,y1) (x2,y2)
plot (x,y,set) is a routine to turn on or off a pixel depending on the value of set.
Bresenham used the finite difference calculus to gain speed and avoid multipication. I have circle algorithms if you are interested
void line(long x1,long y1,long x2,long y2, int set)
long i,line_length,x,y;
signed long deltax,deltay,accm_error;
signed int xchange,ychange;
// bresenham algorithm for lines
disable_interrupts(GLOBAL);
X = x1 ;
Y = y1;
DeltaX = x2 - x1;
DeltaY = y2 - y1 ;
Ychange=1;
Xchange=1;
If (DeltaX < 0 )
XChange = -1 ;
DeltaX = -DeltaX ;
If (DeltaY < 0 )
YChange = -1;
DeltaY = -DeltaY ;
accm_error = 0;
i = 0 ;
If (DeltaX < DeltaY)
Line_Length = DeltaY + 1;
while (i < Line_Length)
Y =Y + YChange ;
accm_error = accm_error + DeltaX ;
IF (accm_error > DeltaY)
X = X + XChange ;
accm_error = accm_error - DeltaY ;
i = i + 1 ;
plot(x,y,set);
Line_Length = DeltaX + 1;
While (i < Line_Length)
X =X + XChange ;
accm_error = accm_error + DeltaY;
If (accm_error > DeltaX)
Y = Y + YChange;
accm_error= accm_error - DeltaX ;
i = i + 1;
plot(x,y,set);
Original Post ID: 9022 |
john lee Guest
Posted: Sat Nov 16, 2002 8:30 am |
:=This will draw a line between cartesian pts (x1,y1) (x2,y2)
:=plot (x,y,set) is a routine to turn on or off a pixel depending on the value of set.
:=Bresenham used the finite difference calculus to gain speed and avoid multipication. I have circle algorithms if you are interested
:=void line(long x1,long y1,long x2,long y2, int set)
:=long i,line_length,x,y;
:=signed long deltax,deltay,accm_error;
:=signed int xchange,ychange;
:=// bresenham algorithm for lines
:=disable_interrupts(GLOBAL);
:= X = x1 ;
:= Y = y1;
:=DeltaX = x2 - x1;
:=DeltaY = y2 - y1 ;
:=Ychange=1;
:=Xchange=1;
:=If (DeltaX < 0 )
:= XChange = -1 ;
:= DeltaX = -DeltaX ;
:=If (DeltaY < 0 )
:= YChange = -1;
:= DeltaY = -DeltaY ;
:=accm_error = 0;
:=i = 0 ;
:=If (DeltaX < DeltaY)
:= Line_Length = DeltaY + 1;
:= while (i < Line_Length)
:= Y =Y + YChange ;
:= accm_error = accm_error + DeltaX ;
:= IF (accm_error > DeltaY)
:= X = X + XChange ;
:= accm_error = accm_error - DeltaY ;
:= i = i + 1 ;
:= plot(x,y,set);
:=else
:= Line_Length = DeltaX + 1;
:= While (i < Line_Length)
:= X =X + XChange ;
:= accm_error = accm_error + DeltaY;
:= If (accm_error > DeltaX)
:= Y = Y + YChange;
:= accm_error= accm_error - DeltaX ;
:= i = i + 1;
:= plot(x,y,set);
:=enable_interrupts(GLOBAL);
Hi, Doug.
Many thanks for your sample, I used a very watered-down version of the bresenham algorithm ,for octant(0) it looks like:
long int x,y,x_count; //x & y are the abs numbers of pulses to output,x_count is the current count in x//
int v_min,v_max,ramp_rate //parameters to the move func
//the move func generates 2 pulse trains to drive 2 machine axes//
//in a co-ordinated move with velocity ramps//
bres_line(x,y) //case for octant(0),where X>=Y
x_count=0 //init x_count
E=(2*y)-(2*x); //inital error(doubled to avoid floats)//
do
if E<0 then E=E+(2*y);
else E=E+(2*y)-(2*x);
pulse_x(); //pulse the major axis,X
if E>=0 then pulse_y();//pulse y if test true
x_count=x_count++; //increment x
while(x_count<=x);
//pulse_x()&pulse_y() are funcs to pulse the axes high for
//10usec. The move() func simply co-ordinates it all, and uses
the rtcc and ccp1 to generate pulses at a variable period, period is updated during the ccp1 interrupt. Works not bad, but
in the real version, I am counting x_pulses on the int_ext,and appear to be getting glitches in the write to the ccp1.
Basically I have been lazy in debugging it, and thought,"Why re-invent the wheel?" Someone somewhere has it all-singing already.
Many thanks for the code, would like to see your circles?
Regards,
John Lee.
Original Post ID: 9033 |
