June Guest
What capacitor is suitable for 20MHz crystal? |
Posted: Fri Nov 15, 2002 5:52 am |
Dear all,
Hi, thanks for all ur help just now. U all are really expert in PIC. Because can answer almost all my questions. How u all learned it?
I'm here having a doubt on what is the suitable capacitor value for 20MHz crystal when using PIC16F876? Because the datasheet shows it can be from 15pF to 33pF. I don't know the larger the better or smaller the better. But at the moment I use 33pF type.
Hope to get your response soon. Thanks.
Regards: June,
___________________________
Original Post ID: 8971 |
Gerrit Faas Guest
Re: What capacitor is suitable for 20MHz crystal? |
Posted: Fri Nov 15, 2002 6:04 am |
Hi june,
For exact frequency it depence on the cystal specs.
For my quick and easy boards I use 18 pF and until know
no problems.
Regards,
Gerrit
:=Dear all,
:= Hi, thanks for all ur help just now. U all are really expert in PIC. Because can answer almost all my questions. How u all learned it?
:= I'm here having a doubt on what is the suitable capacitor value for 20MHz crystal when using PIC16F876? Because the datasheet shows it can be from 15pF to 33pF. I don't know the larger the better or smaller the better. But at the moment I use 33pF type.
:= Hope to get your response soon. Thanks.
:=Regards: June,
Original Post ID: 8972 |
adimot Guest
Posted: Fri Nov 15, 2002 6:22 am |
:=Dear all,
:=Regards: June,
I use 18 pF.
But I had to change the crystal once to make it work. Try that yourself.
This is what I use :
#FUSES HS,NOWDT,NOLVP,NOWRT,NOPROTECT,PUT,BROWNOUT // PIC fuse settings.
Put a 100 nF capacitor near the power pins (19 and 20, GND and +5V). And ground both pins 8 and 19.
Original Post ID: 8977 |
Sherpa Doug Guest
Posted: Fri Nov 15, 2002 7:52 am |
Ask the manufacturer of your crystal.
:=Dear all,
:=Regards: June,
Original Post ID: 8981 |
Miguel Martin Guest
Posted: Sat Nov 16, 2002 4:44 am |
:=Dear all,
Hi. At moment I use 22pF, SMD capacitor. You need some precautions in grounding these capacitors. The point to ground MUST be shortly to VSS pin of the chip. This avoid possibility of ground loops, and works correctly.
Bye.
WMMG
Original Post ID: 9031 |
June Guest
Thanks for your answer |
Posted: Wed Nov 20, 2002 11:50 pm |
Original Post ID: 9198 |
