javi.ar
18F46K22 and ds1307 |
Posted: Fri Mar 16, 2012 8:43 am |
Hi I have been trying to solve an issue regarding ds1307 but still no success,
here is the situation:
18F46K22, LCD and ds1307 , LCD is working fine I can write, no problem, I checked connections , power, 3v coin battery is connected to ds1307, crystal is 32768 hz , there are 4K7 resistors pulling up SDI/SDA and SCL/SCK ports.
when I run ds1307_init() system hangs.
I checked with oscilloscope and no signal goes out from PIN_C3 or PIN_C4 when power up , PIN_C3 is always up (5v) and PIN_C4 is always down (0v).
I use forum CCS driver for ds1307, when I remove ds137_init() it works,
CCS ver is 4.120
here is the code, thanks in advance.
#include <18F46K22.h>
#device adc=16
#FUSES NOPLLEN //4X HW PLL disabled, 4X PLL enabled in software
#FUSES PUT //Power Up Timer
#FUSES WDT_SW //No Watch Dog Timer, enabled in Software
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#use delay(int=16000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=COM1)
//#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,force_hw)
#use i2c(master,fast,sda=PIN_C4,scl=PIN_C3,restart_wdt,force_hw)
#ZERO_RAM
#include <flex_lcd.c>
#include <ds1307.c>
void main(){
//setup_timer_4(T4_DISABLED,0,1);
//setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
ds1307_init();
char k;
lcd_putc("\fPrototipo...\n");
while(TRUE){
lcd_putc('*');
output_toggle (PIN_B5);
delay_ms (500);
Posted: Fri Mar 16, 2012 9:40 am |
First, look carefully at the top of the ds1307.c file. Note it sets up the I2C itself. You need to remove this, or your own setup. Two copies, 'asks for problems'.
Then look at what else is on the pins. Try disabling the ADC.
Then, _do not_ declare variables in the code after functions. This is _not_ legal in C. CCS 'accepts' it, and doesn't complain, but it results in memory areas getting corrupted. This is rapidly becoming something than needs to be in the FAQ. The legal syntax in C, is that variables _must_ be declared at the start of a function, or function block. Though you don't use 'k', put the declaration in the right place.
Just tweaked the code, with these changes, and it is putting data out on the I2C lines. Hangs after sending the address (since I don't have a DS1307 attached). Also changed the I2C setup to:
#USE I2C(MASTER,SLOW,I2C1,FORCE_HW)
Note the 'slow'. The DS1307, supports 100KHz _max_. This is the I2C slow speed, _not_ fast.
javi.ar
Posted: Fri Mar 16, 2012 4:11 pm |
These are the top lines into my ds1307.c file
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#use i2c(master,slow, i2c1, sda=RTC_SDA, scl=RTC_SCL)
#device adc=16
#include <time_reader.h>
#ZERO_RAM
#include <ds1307.c>
void main(){
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
ds1307_init();
while(TRUE){
lcd_putc('*');
//output_toggle (PIN_B5);
delay_ms (500);
I tried all the variants, but no success. Thanks a lot. |
javi.ar
Solved |
Posted: Sun Apr 01, 2012 1:28 pm |
Here is the trick I used to solve it.
I started trimming line by line in ds1307_init () function-.
to see which one make the uc stop. uncomment all, except the second line, write hex file. Uncomment second line, write hex, and VOILA!!! it works...
Don't know what could be affecting, but the trick worked...
Thanks a lot... |
