Array routine not working
Goto page 1, 2, 3  Next
seifpic
PostPosted: Sun Mar 11, 2012 6:57 pm     Reply with quote
I am making a digital clock using LEDs powered by a shift register instead of a 7 segment display. Anyway, since it's going to be powered by a shift register instead of a 7 seg-display, I have made a routine for numbers from 0 to 12 (I made it up to 12 for a specific reason). Anyway, my code doesn't seem to function right (simulating using Proteus Professional 7.7).
here is my code:
#include <16f628a.h>
#use delay (crystal=32768)
   int1 zero[]={true, true, true, true, false, true, true, false};
   int1 one[]={false, false, false, true, false, true, false, false};
   int1 two[]={true, false, true, true, true, false, true, false};
   int1 three[]={true, true, true, false, true, false, true, false};
   int1 four[]={true, true, false, false, true, true, false, false};
   int1 five[]={false, true, true, false, true, true, true, false};
   int1 six[]={false, true, true, true, true, true, true, false};
   int1 seven[]={true, true, false, false, false, false, true, false};
   int1 eight[]={true, true, true, true, true, true, true, false};
   int1 nine[]={true, true, true, false, true, true, true, false};
   int1 ten[]={true, true, true, true, false, true, true, true};
   int1 eleven[]={false, false, false, true, false, true, false, true};
   int1 twelve[]={true, false, true, true, true, false, true, true};
void finset(int1* fnum, char out, char clk) {
int i=1;
   for(i=1; i<=8; ++i) {
      if(fnum[i]) {
         output_high(out);
         output_high(clk);
         output_low(clk);
         output_low(out);
      } else {
         output_low(out);
         output_high(clk);
         output_low(clk);
void num(int rnum, char out, char clk) {
   switch(rnum) {
      case 0:
         finset(zero, out, clk);
      case 1:
         finset(one, out, clk);
      case 2:
         finset(two, out, clk);
      case 3:
         finset(three, out, clk);
      case 4:
         finset(four, out, clk);
      case 5:
         finset(five, out, clk);
      case 6:
         finset(six, out, clk);
      case 7:
         finset(seven, out, clk);
      case 8:
         finset(eight, out, clk);
      case 9:
         finset(nine, out, clk);
      case 10:
         finset(ten, out, clk);
      case 11:
         finset(eleven, out, clk);
      case 12:
         finset(twelve, out, clk);
void main() {
   while(true) {
      num(1, pin_a1, pin_a0);
      delay_ms(1500);
      num(2, pin_a1, pin_a0);
      delay_ms(1500);
      num(3, pin_a1, pin_a0);
      delay_ms(1500);
      num(4, pin_a1, pin_a0);
      delay_ms(1500);
      num(5, pin_a1, pin_a0);
      delay_ms(1500);
      num(6, pin_a1, pin_a0);
      delay_ms(1500);
      num(7, pin_a1, pin_a0);
      delay_ms(1500);
      num(8, pin_a1, pin_a0);
      delay_ms(1500);
      num(9, pin_a1, pin_a0);
      delay_ms(1500);
      num(10, pin_a1, pin_a0);
      delay_ms(1500);
      num(11, pin_a1, pin_a0);
      delay_ms(1500);
      num(12, pin_a1, pin_a0);
      delay_ms(1500);
this is how the finset function should turn out for the number zero:
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
Thanks in advance
PostPosted: Sun Mar 11, 2012 7:29 pm     Reply with quote
well, you've just found out about rule number one.
1) Get rid of Proteus ! It is full of errors, bugs and faulty DRCs.NO version will EVER correctly 'simulate' a PIC.If I had a nickel for every time this comes up,I'd get free lifetime upgrades of PCM !
2) You never say which 'shift register' you're using.There are drivers for some that CCS kindly supplies in the 'examples' folder.
Without knowing the device, no one can properly comment on why you simulated code doesn't work.
Really , you should buy real PICs, a white breadboard and support chips.Everyone here is more than happy to help, but you need to understand, we can only really help with programs running in real PICs.
seifpic
PostPosted: Sun Mar 11, 2012 7:36 pm     Reply with quote
Proteus has worked good so far using this code for zero:
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
It displays zero (the other numbers work too in that way), but using that way for many numbers causes an Out of ROM error: http://www.ccsinfo.com/forum/viewtopic.php?t=47717
The reason I got Proteus was to debug circuits before buying the components. The shift register I'm using is the 74164 sipo.
If proteus isn't good, what other simulator (that has the same functions) do you recommend?[/code]
PostPosted: Sun Mar 11, 2012 8:47 pm     Reply with quote
I can't recommend ANY simulator even though I've got almost 25 years using PICs.No simulator to date (I've tried all of them, ok, a LOT of them) truly 'simulates' PICs. 'Close' is NOT good enough. If it fails ONE aspect of operation, the simulator is garbage.
Nothing compares to real chips in the real world. PICs and other parts are CHEAP compared to 10, 25, 35 years ago and NO amount of 'simulation' will prove that your circuit and code will ACTUALLY work in the real world.
All of the simulators might 'virtually' work but that isn't good enough.
As for your code for the 74164, look at the CCS example for using the '595' shift register and modify it for 74164 operation. It'll produce smaller code and you'll gain a lot of hands on knowledge. There might be a driver in the 'code library' or in the 'examples' folder, I haven't checked to see 'what's new' for several months. If nothing comes up, try 'googling ccs c code 74164'....
dezso
Re: Array routine not working
PostPosted: Sun Mar 11, 2012 11:24 pm     Reply with quote
seifpic wrote:
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_high(out);
output_high(clk);
output_low(clk);
output_low(out);
output_high(clk);
output_low(clk);
That is a duct tape MacGiver version !!!
Try something like this
int8 zero = 0b11110110;
int8 one = 0b00010100;
int8 two = 0b10111010;
void Shift_out(b)
    int8 i = 0;
    for(i=0; i<=8; ++i)             // loop thru 8 bit
        if(bit_test(b,i))           // test if bit set or clear
            output_high(out);       // set output high
            output_high(clk);       // clock
            output_low(clk);
            output_low(out);        // set output low
            output_low(clk);
    Shift_out(two);
    while (true)
I'm could be wrong many time's, at least I know what I'm doing Smile
Mike Walne
Serial to parallel shift register
PostPosted: Wed Mar 14, 2012 7:41 am     Reply with quote
There are possible problems is trying to use the 74164 serial to parallel shift register for this kind of task.
Post a schematic and we may be able to help you.
And I totally endorse temtronic's view. Get rid of Proteus.
Mike
Humberto
PostPosted: Wed Mar 14, 2012 9:05 am     Reply with quote
Sorry, this is coding assembler in C !!!
dezso
PostPosted: Wed Mar 14, 2012 1:01 pm     Reply with quote
Don't see a smile face in your post, have to assume that you aren't kidding Confused
I know assembly, probably more than C, even in asm would use BTFSC and DECFSZ instead of BSF and BCF for shifting out a variable !!
Mike Walne
PostPosted: Wed Mar 14, 2012 6:00 pm     Reply with quote
RD7 -------WWW---------| o o o o o o o o |
RD6 -------WWW---------| o o o o o o o o |
RD5 -------WWW---------| o o o o o o o o |
RD4 -------WWW---------| o o o o o o o o |
RD3 -------WWW---------| o o o o o o o o |
RD2 -------WWW---------| o o o o o o o o |
RD1 -------WWW---------| o o o o o o o o |
RD0 -------WWW---------| o o o o o o 0 0 |
                       | Q Q Q Q Q Q Q Q |
                       | 7 6 5 4 3 2 1 0 |
RB0 -------------------| CK              |
RB1 -------------------| DATA            |
                       |     74HC164     |
The above shows how a 74HC164 MIGHT be connected to a PIC and an 8*8 matrix.
Without confirmation from the original author I have no way of knowing if this suggestion is even close.
In a multiplex display each column (row) is activated in rapid succession.
It's ESSENTIAL to turn the entire display OFF between transitions from one phase to the next.
If the display is not turned off there is leakage between phases.
I'm assuming PortD is row driver (common anodes), and 74HC164 is column driver (common cathodes).
Using '595's the way to drive this kind of setup COULD go as follows.
(1) Turn OFF all column drives i.e. OE off.
(2) Set row drives for current column.
(3) Turn column drive ON for current column i.e. shift column , then OE on.
(4) Repeat (1) (2) (3) for each column 0 to 7 ad nausium.
The 74HC164 does not have '595's output enable so the above can't work.
However, it is possible to operate the other way round.
(1) Turn OFF all row drives i.e. all RDx = 0.
(2) Turn ON current column drive, i.e. shift data in 74HC164.
(3) Set row drives for current column.
Mike
seifpic
PostPosted: Wed Mar 14, 2012 9:19 pm     Reply with quote
Mike
The reason I am not clearing the 74164 shift register between every update is that I am already shifting 8 times for every number. I updated my code and got rid of Proteus as others were suggesting. Now I just need to wait till I get the components to test it.
Function for 74164:
   int8 three = 0b11101010;
   int8 four = 0b11001100;
   int8 five = 0b01101110;
   int8 six = 0b01111110;
   int8 seven = 0b11000010;
   int8 eight = 0b11111110;
   int8 nine = 0b11101110;
   int8 ten = 0b11110111;
   int8 eleven = 0b00010101;
   int8 twelve = 0b10111011;
void Shift_out(int8 b, char out, char clk) {
    int8 i = 0;
            output_high(out);// set output high
            output_high(clk);// clock
    output_low(clk);
void main() {
     Shift_out(zero, pin_b7, pin_b6) ;
PostPosted: Wed Mar 14, 2012 9:51 pm     Reply with quote
What range of index values (i) does your for() loop create ?
Which ones should it create ? Run this test program
to show the indexes that it creates:
#include <16F628A.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS)
int8 i;
for(i=0; i<=8; ++i)
    printf("%u \n\r", i);
Mike Walne
Your schematic
PostPosted: Thu Mar 15, 2012 5:04 am     Reply with quote
here is my code:
OK, so I've got your schematic totally wrong, I read it that you were NOT using a 7 segment display and assumed that you were using some sort of matrix. What I now believe is that you ARE using something similar to a 7 segment display, but driving it from a 74164 rather than directly from a PIC.
So it seems your schematic COULD look like this:-
                       |  74HC164   Q0 |___|\|___/\/\/\___ GND
                       |            Q1 |___|\|___/\/\/\___ GND
RB6 -------------------| CK            |
                       |            Q2 |___|\|___/\/\/\___ GND
RB7 -------------------| DATA          |
                       |            Q3 |___|\|___/\/\/\___ GND
                       |            Q4 |___|\|___/\/\/\___ GND
                       |            Q5 |___|\|___/\/\/\___ GND
                       |            Q6 |___|\|___/\/\/\___ GND
                       |            Q7 |___|\|___/\/\/\___ GND
The LEDs arranged in a pattern:-
      1
    2   7
      3
    4   6
      5   0
please confirm that I have now got somewhere close.
And DO READ PCM programmer's post.
Mike
PostPosted: Thu Mar 15, 2012 5:59 am     Reply with quote
Mike,
A link to an Eagle CAD file with his schematic was posted in another thread: http://www.ccsinfo.com/forum/viewtopic.php?t=47742
seifpic
PostPosted: Thu Mar 15, 2012 9:34 am     Reply with quote
Yeah, it was supposed to do 8 loops but it did nine because I set i to 0. I set it to 1 and it's supposed to work now.
seifpic
Re: Your schematic
PostPosted: Thu Mar 15, 2012 9:41 am     Reply with quote
Mike Walne wrote:
1
2 7
3
4 6
5 0
Mike
You are exactly right. This is the (messy I know) schematic in PNG format: http://i.imgur.com/tfjjc.png
Here is how the LEDs are arranged: http://i.imgur.com/ZFX1z.png
And finally here is my updated code: http://www.ccsinfo.com/forum/viewtopic.php?p=159532#159532
Page 1 of 3
