receive i2c data from pic16f887 to pc by rs232
Goto page Previous  1, 2, 3  Next
Jampe
PostPosted: Tue Mar 13, 2012 10:56 am     Reply with quote
There is someone with an idea?
I want to show something to my teacher on Thursday and I don't know what to do.. Any help is welcome Smile
Thanks,
Jampe.
PostPosted: Tue Mar 13, 2012 11:33 am     Reply with quote
Post a link to the manufacturer's webpage for your ADXL345 board.
I want to see the documenation for the board.
Don't post a link to the Sparkfun website. I looked at all the photos of
Sparkfun boards for the ADXL345, and your board is not in any of those
photos.
Post a link to the true actual website for your ADXL345 board.
Jampe
PostPosted: Tue Mar 13, 2012 11:37 am     Reply with quote
Dear PCM programmer,
Thank you for your post , now I try to use my SRF08 sensor to begin with an easier i2c program.
As you see , I tried jeremiah's code but it didn't work.
I would like to know why does it always show be "FF" , like the code doesn't refer to the address I wrote.
Thanks,
Jampe.
PostPosted: Tue Mar 13, 2012 11:55 am     Reply with quote
The 'classic' reason for 'FF' is that the necessary I2C bus pullup resistors are missing
PostPosted: Tue Mar 13, 2012 11:56 am     Reply with quote
The SRF08 webpage recommends 1.8K pull-up resistors on SDA and SCL.
http://www.robot-electronics.co.uk/htm/srf08tech.shtml
Do you have those resistors installed ?
Does the CCS prototyping board have any pull-up resistors on pins C3
and C4 ? CCS does not post the schematic or the manual for that board
on their webpage. Can you look at the schematic and tell me if it has
any pullup resistors on those pins ?
Jampe
PostPosted: Tue Mar 13, 2012 12:25 pm     Reply with quote
Thank you
I didn't received any resistors from my teacher so I will buy tomorrow like PCM programmer says.. 1.8k
I'm so grateful for your help , both of you.
But there is something weird.. even when I try the 9dof stick , which has pull-up resistors build-in , It shows me "FF".
Thank you for your help , it's so useful!
Jampe.
PostPosted: Tue Mar 13, 2012 12:39 pm     Reply with quote
Here is a diagnostic program (see below) which will look for any i2c slave
devices that are on the i2c bus, and report the slave address for each
one. For example, if I run this program on my PicDem2-Plus board, it
shows the following result in a terminal window (TeraTerm) on my PC:
Start:
ACK addr: 9A
ACK addr: A0
Number of i2c chips found: 2
This means it found the TC74 temperature chip (slave address 0x9A)
and the 24LC256 eeprom (slave address 0xA0). Run the program on
your board and see what it finds.
#include <16F887.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT
#use delay(clock=4M)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
// This function writes the slave address to the i2c bus.
// If a slave chip is at that address, it should respond to
// this with an "ACK".   This function returns TRUE if an
// ACK was found.  Otherwise it returns FALSE.
int8 get_ack_status(int8 address)
int8 status;
i2c_start();
status = i2c_write(address);  // Status = 0 if got an ACK
i2c_stop();
if(status == 0)
   return(TRUE);
   return(FALSE);
int8 i;
int8 status;
int8 count = 0;
printf("\n\rStart:\n\r");
// Try all slave addresses from 0x10 to 0xEF.
// See if we get a response from any slaves
// that may be on the i2c bus.
for(i=0x10; i < 0xF0; i+=2)
    status = get_ack_status(i);
    if(status == TRUE)
       printf("ACK addr: %X\n\r", i);
       count++;
       delay_ms(2000);
if(count == 0)
   printf("\n\rNothing Found");
   printf("\n\rNumber of i2c chips found: %u", count);
Edit: Added carriage return/ linefeed to properly format the output.
Last edited by PCM programmer on Wed Mar 14, 2012 12:05 pm; edited 1 time in total
Jampe
PostPosted: Wed Mar 14, 2012 11:30 am     Reply with quote
PCM programmer , thank you for your demo but I got this :
Start:
ACK addr: 10ACK addr: 12ACK addr: 14ACK addr:
16ACK addr: 18ACK addr: 1AACK addr: 1CACK addr
: 1EACK addr: 20ACK addr: 22ACK addr: 24ACK ad
dr: 26ACK addr: 28ACK addr: 2AACK addr: 2CACK
addr: 2EACK addr: 30ACK addr: 32ACK addr: 34AC
K addr: 36ACK addr: 38ACK addr: 3AACK addr: 3C
ACK addr: 3EACK addr: 40ACK addr: 42ACK addr:
44ACK addr: 46ACK addr: 48ACK addr: 4AACK addr
: 4CACK addr: 4EACK addr: 50ACK addr: 52ACK ad
dr: 54ACK addr: 56ACK addr: 58ACK addr: 5AACK
addr: 5CACK addr: 5EACK addr: 60ACK addr: 62AC
K addr: 64ACK addr: 66ACK addr: 68ACK addr: 6A
ACK addr: 6CACK addr: 6EACK addr: 70ACK addr:
72ACK addr: 74ACK addr: 76ACK addr: 78ACK addr
: 7AACK addr: 7CACK addr: 7EACK addr: 80ACK ad
dr: 82ACK addr: 84ACK addr: 86ACK addr: 88ACK
addr: 8AACK addr: 8CACK addr: 8EACK addr: 90AC
K addr: 92ACK addr: 94ACK addr: 96ACK addr: 98
ACK addr: 9AACK addr: 9CACK addr: 9EACK addr:
A0ACK addr: A2ACK addr: A4ACK addr: A6ACK addr
: A8ACK addr: AAACK addr: ACACK addr: AEACK ad
dr: B0ACK addr: B2ACK addr: B4ACK addr: B6ACK
addr: B8ACK addr: BAACK addr: BCACK addr: BEAC
K addr: C0ACK addr: C2ACK addr: C4ACK addr: C6
ACK addr: C8ACK addr: CAACK addr: CCACK addr:
CEACK addr: D0ACK addr: D2ACK addr: D4ACK addr
: D6ACK addr: D8ACK addr: DAACK addr: DCACK ad
dr: DEACK addr: E0ACK addr: E2ACK addr: E4ACK
addr: E6ACK addr: E8ACK addr: EAACK addr: ECAC
K addr: EE
Number of i2c chips found: 112
By the way , I bought the pull-up resistors (1.8k) as you said , it doesn't solve my problem and jeremiah's code is showing me "0f" .
Where am I wrong?
I've done everything you told me.
Again , I'm very glad you are trying to help me..
Jampe.
PostPosted: Wed Mar 14, 2012 12:38 pm     Reply with quote
I'm sorry about the bad formatting. I posted a slightly earlier version of
the code and it was missing some carriage returns. I have edited my
post and the correct code is now there.
With regard to the output you posted, it obvious it's getting an ACK on
every address. I was able to simulate this by grounding pin C4.
So I wonder if your connections are correct.
Do you have pull-up resistors on pins C3 and C4 ? Or did you accidently
install pull-down resistors by mistake ? Or is some other connection
incorrect, such as power and ground ?
Your pull-up resistor connections should be like this:
              +5v
               > 1.8K
To PIC         |          To i2c slave
pin C4 ------------------ SDA pin
              +5v
               > 1.8K
pin C3 ------------------ SCL pin
Jampe
PostPosted: Wed Mar 14, 2012 2:48 pm     Reply with quote
Thank you for your reply , I used your new code and this is the output :
Start:
ACK addr: E4
I checked the connections and they seems alright.
If the addr is E4 , so my write address is E4?
Thanks,
Jampe.
PostPosted: Wed Mar 14, 2012 2:54 pm     Reply with quote
Yes, the write address is 0xE4, and the read address is 0xE5.
So your #define statements should look like this:
#define  I2C_WRITE_ADDR 0xE4
#define  I2C_READ_ADDR  0xE5
Jampe
PostPosted: Wed Mar 14, 2012 3:03 pm     Reply with quote
I wrote as you say and it shows "data=08" all the time.
This is the code :
#include <16F887.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use delay (clock=20000000)
#use i2c(Master,sda=PIN_C4,scl=PIN_C3)
int8 data;
 i2c_start();                // initiate start condition
  i2c_write(I2C_WRITE_ADDR);            // device address
  i2c_write(0x00);            // register address
  i2c_start();
  i2c_write(I2C_READ_ADDR);            // device address
  data = i2c_read(0);
  i2c_stop();
 printf("data=%x\n",data);
Maybe is the component broken ?
jeremiah
PostPosted: Wed Mar 14, 2012 3:06 pm     Reply with quote
I believe that code just reads the Firmware version or board version, so the value won't change. If it is indeed a revision 8, then that part looks good.
If you want to read the light sensor value, then change the 0x00 to 0x01. If you want to read the first echo high byte, then change 0x00 to 0x02, etc. This is all in the tables located on the page you linked to me in an earlier post.
If you want to read multiple bytes, then change the code to:
#include <16F887.h>
#device adc=16
void main() {
  int8 data[2];  //keep track of the size of this!
  while(TRUE){
    i2c_write(0x02);            // register address
    i2c_start();
    data[0] = i2c_read();
    data[1] = i2c_read(0);   //NACK last byte
    i2c_stop();
    printf("data=%x %x\n",data[0],data[1]);
EDIT: This is assuming of course that the device lets you read more than one byte at a time. If it doesn't, then issue the previous code twice using different register addresses
PostPosted: Wed Mar 14, 2012 3:32 pm     Reply with quote
Try this code to get the range in inches. I don't guarantee this works
because I don't have an SRF08 to test.
#include <16F887.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#define SRF08_WRT_ADDR  0xE4
#define SRF08_RD_ADDR   0xE5
int16 srf08_get_range(void);
int16 result;
   result = srf08_get_range();
   printf("Range in inches = %lu\n\r", result);
int8 lsb;
int8 msb;
int16 range;
// This 1st part sends the ranging command
// to the SRF08 to start it ranging.
i2c_start();
i2c_write(SRF08_WRT_ADDR);
i2c_write(0);
i2c_write(80);  // The range will be returned in inches
i2c_stop();
// Now wait for the ranging to complete.
delay_ms(100);    // Must be 65 ms minimum.
// Finally get the range from the SRF08.
i2c_start();
i2c_write(2);
i2c_start();
i2c_write(SRF08_RD_ADDR);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
range = make16(msb, lsb);
return(range);
Jampe
PostPosted: Thu Mar 15, 2012 12:47 am     Reply with quote
Thank you for your codes..
jeremiah , your code output "data=00 00"..
PCM programmer , your code didn't print anything.
Does that make sense?
For be sure , this is the way I've connected the sensor :
http://img818.imageshack.us/img818/179/img3669copy.jpg
Thanks ,
Jampe.
Page 2 of 3
