allredsd
18F45K22 Sleep and WDT wakeup |
Posted: Tue Mar 13, 2012 10:54 am |
I'm trying to put my 18F45K22 to sleep and have it wake up by WDT to save current when it's idle. I can't get it to work, so I've written a simple test program as provided below. I have no external crystal and am using the internal HF oscillator.
The fuses are set with this code:
//#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale (4ms Resolution) = 0.512 Seconds
//#FUSES WDT256 // Watch Dog Timer uses 1:256 Postscale (4ms Resolution) = 1 Seconds
//#FUSES WDT512 // Watch Dog Timer uses 1:512 Postscale (4ms Resolution) = 2 Seconds
#FUSES WDT32768 // Watch Dog Timer uses 1:1024 Postscale (4ms Resolution) = 4 Seconds
//#FUSES NOWDT //No Watch Dog Timer
//#FUSES WDT
#FUSES WDT_SW //No Watch Dog Timer, enabled in Software
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES PUT //Enable the Power-UP Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode) |
and the test loop is:
Code: | setup_adc_ports(sAN5|sAN6, VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16); //16=263ms //526 ms overflow
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_4,255/*124*/,1); //12.5 us (4kHz) overflow, 12.5 us interrupt
setup_timer_5(T5_DISABLED);
setup_timer_6(T6_DISABLED,0,1);
setup_wdt(WDT_OFF); //turn off the wdt
setup_ccp2(CCP_PWM);
set_pwm2_duty(0); //setup but disable PWM
enable_interrupts(INT_RTCC);
//enable_interrupts(INT_EXT);
//enable_interrupts(INT_RB);
//enable_interrupts(INT_AD);
#ifdef CLOCK_16M
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8); //16=263ms //526 ms overflow
setup_oscillator(OSC_16MHZ|OSC_NORMAL|OSC_31250|OSC_PLL_OFF|OSC_IDLE_MODE);
#endif
#ifdef CLOCK_8M
setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_31250|OSC_PLL_OFF|OSC_IDLE_MODE);
#endif
#ifdef CLOCK_4M
setup_oscillator(OSC_4MHZ|OSC_NORMAL|OSC_31250|OSC_PLL_OFF|OSC_IDLE_MODE);
#endif
int minutes = 0;
int seconds = 0;
int1 pir_active = 1;
int1 run_timer=0;
int1 delay_pir=1;
int1 timer_on = 1;
int1 display_on = 0;
int current_state = STATE_INITIALIZE;
int next_state = STATE_STOPPED;
minutes = read_eeprom(EE_MINUTES);
seconds = read_eeprom(EE_SECONDS);
pir_active = read_eeprom(EE_PIR_ACTIVE);
timer_on = read_eeprom(EE_TIMER_ON);
display_on = read_eeprom(EE_DISPLAY_ON);
WHY_RESET = restart_cause();
//** Turn off Unused Periperals - see datasheet
MCU_PMD0 = 0xFD; //all peripherals off except Timer2
MCU_PMD1 = 0xDD; //all peripherals off except CCP2
MCU_PMD2 = 0x0E; //all peripherals off except ADC
light_led(BLUE);
delay_ms(750);
dark_led(BLUE);
setup_wdt(WDT_ON);
sleep();
delay_cycles(1);
The LED Lights and turns off, then turns back on again (blinking). I don't ever hit the restart_cause() statement, so it appears that the processor isn't going to sleep and being reset by the WDT (I'm running in debugger). Any help would be greatly appreciated!!
Thanks.
Scott |
Posted: Tue Mar 13, 2012 11:17 am |
Quote: |
I'm trying to put my 18F45K22 to sleep and have it wake up by WDT.
I'm running in debugger.
Look at the Help file for ICD2 in MPLAB. Type in 'sleep' and search for it.
Result:
Quote: |
PIC18F Extended, PIC18FXXK Limitations
- The SLEEP instruction cannot be used when debugging.
- The Watchdog Timer (WDT) cannot be used when debugging. |
allredsd
Posted: Tue Mar 13, 2012 11:22 am |
I've tried burning it into rom and get the same results |
Posted: Tue Mar 13, 2012 11:37 am |
1. Make sure your IDE is set to compile and program in "Release" mode.
(not "debug" mode).
2. Simplify your program. Cut out about 90% of your code and test it
again. For example, you have tons of commented out lines, and you have
many lines to setup the Timers, and tons of #ifdefs for different clock
rates. Cut it all out and make a really simple test program. Simplicity
will allow you to see the problem more easily. |
allredsd
Posted: Tue Mar 13, 2012 2:26 pm |
I've found the reason I'm not sleeping or WDT-ing...I had
in my header file. Once I've got that commented out I can see that I'm going to sleep, and waking up on WDT.
For a follow on, I don't seem to be seeing a significant current savings when I go to sleep. Do I have to manually set up the sleep mode before I call sleep() ? |
Posted: Tue Mar 13, 2012 3:36 pm |
Yes, you do. You have to turn off all modules that consume power,
such as the A/D converter, the comparators, Vref generator, etc.
You also have to set all unused i/o pins so they are not floating.
Set unused pins to a low level. If you have an external pull-up or
pull-down resistor on a pin, then set that pin to be an input (ie., floating).
And the truth is, all your unused i/o pins that are not externally
terminated should be set to "output low" during normal operation as well,
so you won't use unnecessary amounts of current due to floating inputs. |
Posted: Wed Mar 14, 2012 2:38 am |
Also, 'think' about what else may be drawing power.
There was another thread involving sleep only a few days ago, and the poster was using a7805 regulator. Problem is that these will typically draw about 5mA, with no load. Possibly 1000* what the PIC may be drawing....
