Pic18f4550 Adc problem
exodia505
PostPosted: Tue Mar 13, 2012 6:25 am     Reply with quote
Hello evrybody!!!
i would like to learn 4 adc values with pic18f4550 , but when i receive them , i dont receive int values , i just receive some chars
i want to know , where is the problem!!
#include <18F4550.h>
#device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#FUSES ICPRT //ICPRT enabled
#use delay(clock=8000000)
int a=0;
int val,val1,val2,val3;
#int_TIMER2
void TIMER2_isr(void)
switch(a)
case 0: set_adc_channel(0);
delay_us(20);
val=read_adc();
a=a+1;
case 1: set_adc_channel(1);
delay_us(20);
val1=read_adc();
a=a+1;
case 2:set_adc_channel(2);
delay_us(20);
val2=read_adc();
a=a+1;
case 3:set_adc_channel(3);
delay_us(20);
val3=read_adc();
a=0;
setup_adc_ports(AN0_TO_AN4|VSS_VDD);
setup_adc(ADC_CLOCK_Div_8);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,60,5);
setup_vref(FALSE);
while(1){
printf("%2u %2u %2u %2u \n\r",val,val1,val2,val3);
NOway!!
gpsmikey
PostPosted: Tue Mar 13, 2012 6:58 am     Reply with quote
Problem starts with no indentation in the code and no comments so people know what you intended to do (including yourself). First thing I see is no "break" in case 2 however, that isn't going to kill the whole program. How do you even know your interrupts are running as expected ? If your code actually does have formatting, then see #5 in http://www.ccsinfo.com/forum/viewtopic.php?t=26245 for posting your example code.
mikey
dyeatman
PostPosted: Tue Mar 13, 2012 7:38 am     Reply with quote
First thing, get rid of these two fuses;
XINST and LVP
They will cause problems. Extended instruction set is not supported and Low
Voltage programming is not being used.
You also want to change NOPUT to PUT.
You need to get rid of the following fuses as well:
This will simplify things a lot...
Google and Forum Search are some of your best tools!!!!
PostPosted: Tue Mar 13, 2012 7:57 am     Reply with quote
also always add 'errors' to the use rs232(....) statement when using the hardware UART.
dyeatman
PostPosted: Tue Mar 13, 2012 8:04 am     Reply with quote
These lines are trying to prinf() multiple times per second which you do not need.
while(1){
You are also trying to put 10 bit ADC values into an 8 bit integer variable.
INT defaults to 8 BIT in this compiler.
asmboy
PostPosted: Tue Mar 13, 2012 9:24 am     Reply with quote
instead of setting the ADC channel - THEN adding a delay - THEN reading
( which flirts with the MINIMUM ACQ time)
WHY NOT set the NEXT Channel you will read AFTER taking a reading on the current selected input- and THEN when you come back on the timer INT - just READ the LAST channel that was set to acquire ??
try this
// in your INIT code
STATIC int a=0;
STATIC int16 val[4];
set_adc_channel(a);
#int_TIMER2
void TIMER2_isr(void) {
   val[a]=read_adc();
   a++;
   if (4==a) a=0;
   set_adc_channel(a);
Learn to THINK in the time domain and all your PIC code will get better
asmboy
PostPosted: Tue Mar 13, 2012 11:52 am     Reply with quote
oh yes
add "ERRORS" to your #USE RS232 directive
