vasanthan
RS-232 and LCD |
Posted: Tue Mar 13, 2012 2:50 am |
Hi everyone,
I am using PIC 16F887 and CCS-C compiler(version 4.093) plugin in MPLAB IDE ... i simulated the design in proteus and .. its working perfectly.. now i am implementing the same design in hardware ... RS232 module is working separately but does not work when LCD is initialised .. in the code i have disabled two lines .. without these lines code is working .. when these codes are made active there is no output in hardware(computer-hyperterminal). LCD connections are in port D rs232 connections use RC6 and RC7.. where is the problem ? why is RS232 not working when LCD is initialised ?
can you please help me ?
#include <16f887.h>
#device ADC=10
#use delay(clock=16000000)
#use RS232(baud =9600, xmit = PIN_C6, rcv = PIN_C7)
#include <lcd.c>
setup_adc(ADC_CLOCK_DIV_8);
//lcd_init();
//printf( lcd_putc, "Battery Status\n" );
printf ("Battery discharge monitoring \n\r" );
putc('c');
puts("\n\rtemperature measurement");
Posted: Tue Mar 13, 2012 4:04 am |
Comments first:
ADC_CLOCK_DIV_8, is too fast for 16MHz operation. You need DIV_32.
Add ERRORS to your RS232 declaration. This _must_, repeat _must_ be present when using the hardware UART, unless you add your own error handling code. It is not optional, but _required_.
Without this, the receive UART can become 'hung', if data is arriving and not being read.
Now, post your pin connections for the LCD, and triple check the settings you are using. I'd guess, that you have a problem here, and the status line from the LCD is not being seen by the PIC. It therefore hangs, waiting for the LCD...
Switch the the flex_lcd driver, set it up to match your connections, and try it with 'USE_LCD_RW' disabled. If the serial starts working, then this proves what is happening, and it'll just be a matter of finding 'why'.
Alternatively, I'd be looking for a wiring problem. Possibly a wire whisker somewhere.
dezso
Posted: Tue Mar 13, 2012 9:41 am |
Code: | #include <16f887.h>
#device ADC=10
#include <lcd.c>
lcd_init(); // You only need to init LCD once !!
putc('c');
_________________ I'm could be wrong many time's, at least I know what I'm doing |
vasanthan
RS232 and LCD PIC16F887 |
Posted: Wed Mar 14, 2012 4:03 am |
Thanks for your support ...its working now
Thanks and Regards
vasanth |
