Problem With SPI again..
kagalou
PostPosted: Thu Mar 08, 2012 7:11 am     Reply with quote
Hi everyone, I come back because I have a new problem..
I use ISIS for simulation .. But I need a clock to simulate the SCK from SPI..
Thank's For help
Mike Walne
Forget Proteus.
PostPosted: Thu Mar 08, 2012 9:32 am     Reply with quote
Throw proteus away. It's so full of bugs most of the guys here, who can help, will not even try.
Follow the CCS forum guide.
Post a SHORT compilable section of code which shows the problem, with your version No.
Tell us CONCISELY what your code does / does not do, and what you think it should do.
Use real hardware.
Mike
PostPosted: Thu Mar 08, 2012 1:49 pm     Reply with quote
No...it's the same problem, you're STILL trying to use Proteus!!!
Mike's RIGHT, throw it away......!!
PostPosted: Thu Mar 08, 2012 2:14 pm     Reply with quote
This post has a simple program to generate an SPI clock and data (for
testing, to see with an oscilloscope):
http://www.ccsinfo.com/forum/viewtopic.php?t=44760&start=1
karimpain
View user's profile Send private message AIM Address MSN Messenger ICQ Number
PostPosted: Fri Mar 09, 2012 12:06 pm     Reply with quote
Really i don't understand the real problem or maybe your question. But look at this master and slave codes and using isi proteus. It works and either i think in reality hope it can help you. Don't forget to connect the csk together and sdo of the master to sdi of slave:
Master code:
#include <16F877a.h>
#fuses HS
#define SLAVE_SELECT  PIN_C0
#define DI            PIN_C4
#define DO            PIN_C5
#define CLK           PIN_C3
#byte port_c=7
#byte port_d=8
   byte value;
   set_tris_c(0x10);
   set_tris_d(0xff);
   output_low(CLK);
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
   while(true){
      value=port_d;
      spi_write(value);
      delay_ms(10);
      output_high(SLAVE_SELECT);
slave code:
#fuses HS
#define DI            PIN_C4
#define CLK           PIN_C3
#byte port_b=6
#byte port_c=7
#byte port_d=8
   byte value;
   set_tris_c(0x14);
   set_tris_d(0x00);
   setup_spi(SPI_SLAVE | SPI_H_TO_L|SPI_CLK_DIV_16);
   while(true){
    spi_read(0);
  if(spi_data_is_in()){
    value=spi_read();
    port_d=value;
    switch (value)
      case 0x01:
      port_d=0x01;
      case 0x02:
      port_d=0x02;
      case 0x04:
      port_d=0x04;
      case 0x08:
      port_d=0x08;
      case 0x10:
      port_d=0x10;
      case 0x20:
      port_d=0x20;
      case 0x40:
      port_d=0x40;
      default:port_d=0x00;
      break;}
    delay_ms(10);
PostPosted: Fri Mar 09, 2012 1:22 pm     Reply with quote
byte value;
set_tris_c(0x10);
set_tris_d(0xff);
output_low(CLK);
while(true){
value=port_d;
spi_write(value);
delay_ms(10);
This is not a good example program. It doesn't initialize the SS line
to an inactive level at the beginning. Also, it only sets SS high inside
the loop. It never sets SS low, which it should do before the spi_write().
If it works in Proteus, then it shows how bad Proteus is, because it means
Proteus doesn't check the SS line for the SPI slave.
