bit_test a constant
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
bit_test a constant
PostPosted: Fri Mar 09, 2012 2:17 am     Reply with quote
Is there an easy way to bit_test a constant? the in-built bit_test function doesn't allow it.
PostPosted: Fri Mar 09, 2012 2:48 am     Reply with quote
Seems totally pointless. After all a constant, is constant, so the bit test is always going to return the same value.....
You can always just use a simple '&' test.
#define constant_bit_test(X,Y) (X&(1<<Y)!=0)
Will Reeve
PostPosted: Fri Mar 09, 2012 3:45 am     Reply with quote
thanks, they are "variable" constants in a separate file which are calibration constants to each micro but change for each device (separate file for each product)! As the compiler knows where in program space it has stored them I thought it might allow bit_wise access to them with an inbuilt function.
Your neat code looks great. Thanks.
