1980best
(24FV32KA302) secondary oscillator = I O do |
Posted: Wed Mar 07, 2012 7:52 am |
#include <24FV32KA302.h>
#device ADC=12
#FUSES NOBROWNOUT
#FUSES NOWDT
#FUSES ICSP1
#FUSES OSCIO
#FUSES PR //Primary Oscillator
//#FUSES MCLR
#FUSES debug
// #FUSES SOSC_DIG error // SOSC_DIG Digital mode, I/O port functionality of RC0 and RC1 //
// #FUSES SOSC_IO error //////SOSC_IO SOSC pins have digital I/O functions //////
...................PROBLEM
I WANT to use IO as a secondary oscillator.
12 SOSCO/SCLKI/U2CTS/CN0/RA4
11 SOSCI/AN15/U2RTS /CN1/RB4
but not to be...........error.....
pdf
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en552766
thanks |
1980best
Posted: Thu Mar 08, 2012 12:42 am |
#fuses SOSC_DIGITAL // error
ERROR unknown keyword in #FUSES "SOSC_DIGITAL" |
1980best
Posted: Thu Mar 08, 2012 12:44 am |
pcwhd version 4.124 |
1980best
Posted: Thu Mar 08, 2012 12:45 am |
//////// Standard Header file for the PIC24FV32KA302 device ////////////////
#device PIC24FV32KA302
#nolist
//////// Program memory: 11264x24 Data RAM: 2048 Stack: 31
//////// I/O: 23 Analog Pins: 13
//////// Data EEPROM: 512
//////// Fuses: WRTB,NOWRTB,BSSH2560,BSSH1152,BSSS2560,BSSS1152,NOBSS,WRT
//////// Fuses: NOWRT,PROTECT,NOPROTECT,FRC,FRC_PLL,PR,PR_PLL,SOSC,LPRC
//////// Fuses: LPFRC_DIV,FRC_DIV,NOIESO,IESO,EC,XT,HS,NOPR,OSCIO,NOOSCIO
//////// Fuses: POSCFREQ_L,POSCFREQ_M,POSCFREQ_H,SOSC_LOW,SOSC_HIGH,CKSFSM
//////// Fuses: CKSNOFSM,NOCKSFSM,WPOSTS1,WPOSTS2,WPOSTS3,WPOSTS4,WPOSTS5
//////// Fuses: WPOSTS6,WPOSTS7,WPOSTS8,WPOSTS9,WPOSTS10,WPOSTS11,WPOSTS12
//////// Fuses: WPOSTS13,WPOSTS14,WPOSTS15,WPOSTS16,WDT32,WDT128,NOWINDIS
//////// Fuses: WINDIS,NOWDT,WDT_NOSLEEP,WDT_SW,WDT,NOBROWNOUT,BROWNOUT_SW
//////// Fuses: BROWNOUT_NOSL,BROWNOUT,NOPUT,PUT,ALTI2C,NOALTI2C,LPBORV
//////// Fuses: BORV_HIGH,BORV_MID,BORV_LOW,NOMCLR,MCLR,ICSP3,ICSP2,ICSP1
//////// Fuses: DEBUG,NODEBUG,DSWDT2,DSWDT8,DSWDT32,DSWDT128,DSWDT512
//////// Fuses: DSWDT2048,DSWDT8192,DSWDT32768,DSWDT131072,DSWDT524288
//////// Fuses: DSWDT2097152,DSWDT8388608,DSWDT33554432,DSWDT134217728
//////// Fuses: DSWDT536870912,DSWDT2147483648,DSWDTCK_SOSC,DSWDTCK_LPRC
//////// Fuses: NODSBOR,DSBOR,NODSWDT,DSWDT
////////////////////////////////////////////////////////////////// I/O
// Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
// SET_PULLUP(), INPUT(),
// OUTPUT_LOW(), OUTPUT_HIGH(),
// OUTPUT_FLOAT(), OUTPUT_BIT()
// Constants used to identify pins in the above are: |
FvM
Posted: Thu Mar 08, 2012 2:34 am |
I see that fuse settings for 24FV32KA302 aren't correctly implemented in PCD V4.124.
As previously discussed, you have either the option to correct/supplement the fuse setting with the device editor tool,
or to specify appropriate configuration words with a #rom statement. Or use the most recent PCD version. |
1980best
Posted: Thu Mar 08, 2012 7:11 am |
FvM wrote: | I see that fuse settings for 24FV32KA302 aren't correctly implemented in PCD V4.124.
thanks
problem is solved by using pcwhd 4.128
//#FUSES SOSC_DIG
//#FUSES SOSC_IO
//#FUSES SOSC_DIGITAL
#FUSES SOSC_ANALOG
#FUSES SOSC_ANALOG // ok |
