PIC18F4550 ECCP PWM
samuel yap
PIC18F4550 ECCP PWM
PostPosted: Tue Mar 06, 2012 10:41 am     Reply with quote
If i just set the CCP1CON to full bridge forward/reverse, it will automatically configure the pins P1A, P1B, P1C,P1D ?
for example :
setup_ccp1(CCP_PWM_FULL_BRIDGE | CCP_PWM_H_H);
delay_ms(5000);
// Run in reverse for 5 seconds.
setup_ccp1(CCP_PWM_FULL_BRIDGE_REV | CCP_PWM_H_H);
delay_ms(5000);
can this simple code run forward in first 5 second then run reverse in next 5 second?
PostPosted: Tue Mar 06, 2012 2:54 pm     Reply with quote
Yes, that should work OK.
Mike Walne
Be careful
PostPosted: Tue Mar 06, 2012 5:50 pm     Reply with quote
The data sheet outlines the precautions you may need to take when attempting to reverse direction.
Mike
