Chaud
My math operators, are not working as i want |
Posted: Tue Mar 06, 2012 1:07 pm |
Double conta = 100 * 0.0512;
printf("%ld \r\n",conta); |
Result expected = 5.12
Result i get = 9089 |
curt2go
Posted: Tue Mar 06, 2012 1:18 pm |
Try this
Float conta = 100 * 0.0512;
printf("%2.2f \r\n",conta); |
SherpaDoug
Posted: Tue Mar 06, 2012 1:19 pm |
I believe you are printing it as if it was an integer. Look at the formats for printf(). _________________ The search for better is endless. Instead simply find very good and get the job done. |
Chaud
Posted: Tue Mar 06, 2012 1:27 pm |
if i change "conta" to float, it works curt2go
Isnt it supossed to work with double too? |
curt2go
Posted: Tue Mar 06, 2012 1:41 pm |
Double is not used by CCS...
C Standard Type
Default Type
short
int1
char
unsigned int8
int
int8
long
int16
long long
int32
float
float32
Hope that helps.. |
FvM
Posted: Tue Mar 06, 2012 1:44 pm |
C-standard type specifier for double is %g not %d. It's listed as "rounded decimal" float format in the CCS C manual, however.
Quote: | Double is not used by CCS... |
Double is supported in PCD. |
Chaud
Posted: Tue Mar 06, 2012 1:59 pm |
Ok i get it, thanks for you help ![Smile](images/smiles/icon_smile.gif) |
