wdt problem from sleep
Steveny
PostPosted: Thu Nov 14, 2002 2:33 pm     Reply with quote
I'm using timer2 on a 16f628 to transmit data at a given rate for given time period. However I need the PIC to go to sleep in between data burst. Unfortunately i can't seem to wake the PIC up again using the WDT when its a sleep. It seems to work ok when I don't have it in sleep mode or use a wdt.
I've listed the basics of the programs below and how i set most the things up. I also make sure that I have restart the wdt before it times_out and resets.
Cut down version of program
#include "16F628.h"
#fuses XT,WDT,NOPROTECT
#use Delay (clock=4000000)
#int_timer2
/*interrupt handler */
handler() {
restart_wdt();
do other stuff...
void main(void) {
set_tris_a(0xFF) ; /*set all port a for input*/
set_tris_b(0x00) ; /*set all port b for output*/
setup_timer_2(T2_DIV_BY_1,128,2);
setup_wdt(WDT_18MS);
enable_interrupts(INT_TIMER2) ;
enable_interrupts(GLOBAL) ;
while(1) {
restart_wdt();
sleep();
do stuff.......using inturrupt handler for given
time period..when finished go back to sleep.
Any help much appreciated..
Steve
___________________________
Original Post ID: 8939
Tomi
Re: wdt problem from sleep
PostPosted: Fri Nov 15, 2002 2:17 am     Reply with quote
Clock is off under sleep so Timer2 never incremented under sleep. Use Timer1 with external 32768 Hz xtal and use Timer1 interrupt for both wakeup and timing the transmit.
:=Hi,
:=I'm using timer2 on a 16f628 to transmit data at a given rate for given time period. However I need the PIC to go to sleep in between data burst. Unfortunately i can't seem to wake the PIC up again using the WDT when its a sleep. It seems to work ok when I don't have it in sleep mode or use a wdt.
:=I've listed the basics of the programs below and how i set most the things up. I also make sure that I have restart the wdt before it times_out and resets.
:=Cut down version of program
:=#include "16F628.h"
:=#fuses XT,WDT,NOPROTECT
:=#use Delay (clock=4000000)
:=#int_timer2
:=/*interrupt handler */
:=handler() {
:= restart_wdt();
:= do other stuff...
:=void main(void) {
:= set_tris_a(0xFF) ; /*set all port a for input*/
:= set_tris_b(0x00) ; /*set all port b for output*/
:= setup_timer_2(T2_DIV_BY_1,128,2);
:= setup_wdt(WDT_18MS);
:= enable_interrupts(INT_TIMER2) ;
:= enable_interrupts(GLOBAL) ;
:= while(1) {
:= restart_wdt();
:= sleep();
:= do stuff.......using inturrupt handler for given
:= time period..when finished go back to sleep.
:=Any help much appreciated..
:=Steve
Original Post ID: 8958
Steveny
PostPosted: Fri Nov 15, 2002 5:18 am     Reply with quote
I've fixed the problem now by using
setup_counters(RTCC_INTERNAL, WDT_2304MS);
the first timer0 as the wdt. However there is an error in the code below in which I forgot to put a delay instruction to allow the interrupt to happen a number of times before it went back to sleep. So the pic woke up checked somthing and went back to sleep before the interrupt had time to transmit data. DOH!!!
:=Clock is off under sleep so Timer2 never incremented under sleep. Use Timer1 with external 32768 Hz xtal and use Timer1 interrupt for both wakeup and timing the transmit.
:=:=Hi,
:=:=I'm using timer2 on a 16f628 to transmit data at a given rate for given time period. However I need the PIC to go to sleep in between data burst. Unfortunately i can't seem to wake the PIC up again using the WDT when its a sleep. It seems to work ok when I don't have it in sleep mode or use a wdt.
:=:=I've listed the basics of the programs below and how i set most the things up. I also make sure that I have restart the wdt before it times_out and resets.
:=:=Cut down version of program
:=:=#include "16F628.h"
:=:=#fuses XT,WDT,NOPROTECT
:=:=#use Delay (clock=4000000)
:=:=#int_timer2
:=:=/*interrupt handler */
:=:=handler() {
:=:= restart_wdt();
:=:= do other stuff...
:=:=void main(void) {
:=:= set_tris_a(0xFF) ; /*set all port a for input*/
:=:= set_tris_b(0x00) ; /*set all port b for output*/
:=:= setup_timer_2(T2_DIV_BY_1,128,2);
:=:= setup_wdt(WDT_18MS);
:=:= enable_interrupts(INT_TIMER2) ;
:=:= enable_interrupts(GLOBAL) ;
:=:= while(1) {
:=:= restart_wdt();
:=:= sleep();
:=:= do stuff.......using inturrupt handler for given
:=:= time period..when finished go back to sleep.
:=:=Any help much appreciated..
:=:=Steve
Original Post ID: 8969
