migrating from pcw to pcd
Goto page 1, 2  Next
osu1177
PostPosted: Mon Feb 27, 2012 3:07 pm     Reply with quote
Hi All,
I have been programming 16f877a chips and below, and am no expert by any means. My latest application requires the use of at least 3 hardware UART's, so I am looking at the 24 series. In order to use these, I would have to transition from my trusty pcw compiler to pcd.
Would it be difficult to port my 16f877a code to a PIC24FJ64GA306, for example? Or would it be rather straight forward?
Any thoughts?
Thanks for your time, as always.
David
asmboy
PostPosted: Mon Feb 27, 2012 3:29 pm     Reply with quote
it all depends on your code
basic stuff you have done should be fine
PostPosted: Mon Feb 27, 2012 3:35 pm     Reply with quote
Lots of thoughts...
Migrating to a different series can be painful! First be sure your programming hardware/software WILL program the chips you select.Apparently the PK3 has 'issues'.
As well, there's the 'learning' curve getting to know the differences the 'new' PIC has that aren't compatible with 'old' PICs.
The 24 and 33 series aren't as popular as the 16 and 18s are.Perhaps a 'high powered' 18 PIC will do the job? You mention 3 UARTS,perhaps an external I2C or SPI device could be used? especially if speed isn't a huge factor?
You might find using a PIC you know(or very similar) and some support chips might make the product 'faster to market'.Also ther's the cost factor, but PICs are cheap it's the R&D(labour) that costys the real $$$$!
asmboy
PostPosted: Mon Feb 27, 2012 5:13 pm     Reply with quote
Let me add - there are several 18f46K parts that have DUAL UARTS on board -
and if you have RTS-CTS control over two of your ports - you could multiplex back and forth checking for incoming data release on your falling CTS - over a given time window using just ONE of the dual uarts -
with the right circumstances THAT would be 3 port support.
Very Happy Very Happy
asmallri
PostPosted: Mon Feb 27, 2012 6:38 pm     Reply with quote
temtronic wrote:
Lots of thoughts...
The 24 and 33 series aren't as popular as the 16 and 18s are....
I am sure this is cause and effect related. Lots of schools teach the basic PIC16F. Cheap tools (free compilers) drives this behaviour.
Personally I stopped using the PIC16F family in 2004, and stopped using the PIC18F family for new hardware designs in 2007.
My default processor for new hardware designs is the PIC24/dsPIC33 or, for complex networking based applications, the PIC32
The internal architecture of the PIC24, the bus width, Interrupt Vector Tables, larger RAM, and rich peripheral set makes this PIC a great choice for developing application and bringing them to market quicker than on the legacy PIC predecessors.
For non-complex high volume applications where every cent counts, then PIC18s and PIC10s etc definitely have their place.
The good thing about the CCS family of compilers is that code portability between PIC families is relatively straight forward and the bulk of the code can be migrated unchanged unlike the nightmare of doing this with Microchip's compilers each with their compiler specific linker scripts.
Regards, Andrew
asmboy
PostPosted: Mon Feb 27, 2012 7:15 pm     Reply with quote
osu1177 - let me put it to you like this:
Wise developers make ALL decisions, for every engineering project
based on the functionality you need and the cost to produce that design-
in the intended volume and beyond.
In my case the design is driven by ONLY those factors.
having never been hired to create an MP3 player or pocket video recorder -
I have always been able to satisfy myself and my customers with very low cost pics. A month ago I did a design that was best handled by an 18F4620.
Last week I did an uninterruptable lighting controller with a 16HV616 and this afternoon decided that I would probably use a 10Fas the clever, low $$ way - to do an LED lighting modulator.
If you decide on only ONE family of PICS in advance of fleshing out
your whole project - you run the risk of paying too much to produce it -
at the MINIMUM.
osu1177
PostPosted: Wed Feb 29, 2012 12:09 pm     Reply with quote
Thank you all for the thoughtful responses. I do appreciate it greatly.
I had migrated from a 16f877a to a 16f1824, without any hiccups. If the process would be similarly easy to the 24 series, I would venture to do so; the 24 series have a lot of features which would come in handy for this project.
However, I do have concerns based on what I have read. And, as temtronic has mentioned, there are alternative venues involving external comm devices.
What I need is 6 channel, full-duplex asynchronous communication. Any comm protocol that involves a buffer (FIFO, shift register, etc) should work fine.
My idea was to use 2 24 series PICS, that have 4 UARTS each (3 for their own purpose, the fourth as comm between the two pics).
As all of you have mentioned at one point or another, cost is of extreme importance, so this seems like the best option so far. All of the external UART chips become rather expensive when you need 6 channels.
Having explained that, perhaps some of you may be able to offer a more attractive solution?
asmallri
PostPosted: Wed Feb 29, 2012 12:27 pm     Reply with quote
Yes and No. The CCS compiler make it relatively easy to migrate from PIC16 to PIC18 to PIC24.
Unfortunately there is no CCS PIC32 compiler option. The PIC32 supports 6 UARTS and is a powerful processor. Faced with your same task, I would look at it however if you do then you would need to use the Microchip C32 compiler.
Regards, Andrew
PostPosted: Wed Feb 29, 2012 12:59 pm     Reply with quote
6 serial ports is one thing, but at what SPEED ??? Also how they are configured( eg.5 as inputs----> 1 output, 3 in:3 out,anyone to anyone) ?
Is there a 'master' or are they all? Collisions !!!
Also the amount of data that they have to process is important as well as flow. Small chunks of data or streams of hundreds of bytes ?
Others can probably think of 100 or more questions to ask, details to 'iron out' !
osu1177
PostPosted: Wed Feb 29, 2012 5:19 pm     Reply with quote
9600 baud (though this can be changed), small data chunks
full duplex, asynchronous communication is a must (to answer your master/slave question)
the buffer size required is only 1 to 2 bytes for now...so we are not dealing with large amounts of buffered memory
Right now I am leaning towards 2 24 series PICS, each of which have 4 UARTS, 3 on each one for external comm, and 1 on each one to communicate between PICS....
asmboy
PostPosted: Wed Feb 29, 2012 6:22 pm     Reply with quote
DO YOU HAVE CTS -RTS hardware handshaking possible on the remote RS-232 devices?
if you answer YES -
then you can do a LOT of clever stuff with fewer serial ports ports than you think you need now .
osu1177
PostPosted: Thu Mar 01, 2012 9:50 am     Reply with quote
asmboy- I was able to find a few UART's with 2 channels that contain transmit and receive ready functions built into the hardware, but I do not yet see how I can use these for 6 channels. Are you talking about multiplexing the 2 channels into 6?
asmboy
PostPosted: Thu Mar 01, 2012 2:14 pm     Reply with quote
- you CAN share a single serial port with various devices by using
1- hardware handshaking ala RTS-CTS
2- multiplexing the TX - RX line
Thus a single RS-232 port can allocate time windows when it allows
each slave, by turns - one at a time - to exclusively talk and receive ,
- ALL in a time slot that your program chooses.
B U T -- for this to work however - any rs-232 clients must be able to work with CTS-RTS handshaking control.
You can MUX select your master pic RX channel with a set of latches
that let only ONE slave at a time talk to a single shared UART.
if your slaves do are not capable of "holding off" transmit - then you WILL need individual UARTS .
devices that CAN usually work with RTS-CTS :
printers && PCS and modems
devices that CAN'T:
streaming data services (ala stock tickers )
and sattelite delivered Reuters News data
READ about CTS RTS handshaking to get the idea
asmallri
PostPosted: Thu Mar 01, 2012 5:00 pm     Reply with quote
9600 baud is very slow. It is easy, especially with a PIC24, to implement multiple 9600 baud, timer interrupt driven, full duplex software UARTs. It could be done with a single timer. Unless you have some other reason for using two PICs, I would use a single PIC24 to handle all 8 UARTs.
Alternatively you could add a pair of MAX3110E or MAX3111E or equivalent. These are dual slave UARTs with RS232 line drivers than connect to the PIC via the SPI bus.
Regards, Andrew
asmboy
PostPosted: Thu Mar 01, 2012 5:08 pm     Reply with quote
your problem CAN surely be resolved in one of several ways -
BUT
you need to reveal WHAT you rs-232 Clients ARE
if we are going to be able to help you figure that out.
Goto page 1, 2  Next
Page 1 of 2
