redicon
| #use rs232 and set_tris_b |
Posted: Sun Feb 26, 2012 11:04 am |
Hi to all,
I'm using pic16f88 uart, by code:
| Code: | | #use rs232(baud=9600,xmit=PIN_B5,rcv=PIN_B2,parity=N,bits=8,ERRORS) |
I also need to use PIN_B3 as output to control a led.
So I use:
| Code: | | set_tris_b(4); //PIN_B2 serial input, others output |
but nothing works. Where is the problem in set_tris_b?
Thanks |
dyeatman
Posted: Sun Feb 26, 2012 11:36 am |
What fuses have you set? Show us your fuses line. _________________ Google and Forum Search are some of your best tools |
redicon
Posted: Sun Feb 26, 2012 11:47 am |
Here is complete program:
| Code: | #include <16F88.h>
#FUSES INTRC_IO //Internal RC Osc
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES NOLVP //No low voltage programing, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NODEBUG //Debug mode for use with ICD
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#define TIMER0INIT 59286
#use delay(clock=2000000)
#DEFINE LED PIN_B3
int cont = 0;
#int_TIMER1
//interrupt each 0,1 s
void timer1_isr(void)
cont++;
set_timer1(TIMER0INIT);
main()
setup_oscillator(OSC_2MHZ);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
set_tris_b(4); // b2 serial input
OUTPUT_LOW(LED);
setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8);
if (cont == 30) // after 3sec
cont =0;
OUTPUT_HIGH(LED);
without #use rs232 this program is working fine, using rs232 there is a problem on portb and the led starts high.
SherpaDoug
Posted: Sun Feb 26, 2012 12:35 pm |
Unless you need to use fast_IO, which is rare, you should not need to set the TRIS registers at all. The compiler does it for you automatically.
Can you write a simple program to blink your LED on B3? Do you have a hardware problem? _________________ The search for better is endless. Instead simply find very good and get the job done. |
redicon
Posted: Sun Feb 26, 2012 12:57 pm |
No hardware problem, my program can blink led well without #use rs232 statement.
Also removing the set_tris function the led starts high. Are you sure that i don't need to set tris? |
Douglas Kennedy
Posted: Sun Feb 26, 2012 1:45 pm |
Try instead of if (cont == 30) // after 3sec this
if (cont >= 30) // after 3sec |
redicon
Posted: Sun Feb 26, 2012 5:49 pm |
Nothing changes.
If I add "#use rs232" statement the program stop working.
The problem is in set_tris+use rs232 (i've also tried #use fast_io(B), nothing change) |
redicon
Posted: Sun Feb 26, 2012 8:49 pm |
| My version is 4.016, quite old. |
Posted: Sun Feb 26, 2012 11:06 pm |
I don't have vs. 4.016, but I do have 4.014 and 4.017. So I copied and
pasted your program into MPLAB and compiled it and saved the .LST
file in another directory. Then I commented out the #use rs232 line and
re-compiled it. Then I compared the two .LST files. The only real
differences that I saw, was that the file with #use rs232() in it had the
following lines to setup the UART.
| Quote: |
0046: MOVLW 0C
0047: MOVWF SPBRG
0048: MOVLW A6
0049: MOVWF TXSTA
004A: MOVLW 90
004B: BCF STATUS.RP0
004C: MOVWF RCSTA
I didn't see any lines in the .LST file that would change the TRIS on pin B3
to be an input, which would prevent it from driving the LED.
Here's the code in vs. 4.014. CCS does do something a little weird.
They use the obsolete TRIS instruction even though the 16F88 data sheet
says not to use it. But it shouldn't matter anyway because in the next
lines, CCS sets the TRISB.3 bit = 0, which makes it an output pin.
.................... set_tris_b(4); // b2 serial input
006C: MOVLW 04
006D: TRIS 6
.................... OUTPUT_LOW(LED);
006E: BSF 03.5 // Bank 1
006F: BCF 06.3 // TRISB.3 = 0
0070: BCF 03.5 // Bank 0
0071: BCF 06.3 // PortB.3 = 0
Maybe I missed something, but do you guarantee that merely
un-commenting the #use rs232() line will make the LED fail to turn on ?
If it does, I think you should strip down the program to almost nothing.
Get rid of 90% of the code and make a test program for the LED and
#use rs232() only. See if adding #use rs232() really makes the LED
fail to turn on. |
RF_Developer
Posted: Mon Feb 27, 2012 2:26 am |
There's a lot of confusion here... set_tris_x() only has any effect if fast_io is set for that port. As has pointed out you are not using fast_io. Even if you were, your set_tris_b() will do precisely the opposite of what you say it does. All IOs are inpus by default (which is why your LED "starts high" when you omit the set_tris, in fact it will always "start high", i.e,. be pulled high by the LED, until you set the tris in fast io mode, or output to it the first time in standard IO mode) and must be actively set as outputs by setting the relevant tris bit high. So your statement:
should read
set_tris_b(251); //PIN_B2 serial input, others output
This also illustrates a problem with using decimal constants in set_tris(): its very confusing. Its probably best here to use binary constants as its much clearer. Hex is better than decimal, but not as clear as binary:
set_tris_b(0b11111011); //PIN_B2 serial input, others output
Also you must be aware that manually setting the tristate control for a port can conflict with other uses for that port, in this case the UART. Also your use rs232 may well override your tris setting, or part of it. In any case your application doesn't need fast io, and all these confusions.
RF Developer |
redicon
Posted: Mon Feb 27, 2012 5:39 am |
RF_Developer in TRIS register 0 make pin as output, 1 as input.
This line is wrong
| Code: | | set_tris_b(0b11111011); //PIN_B2 serial input, others output |
Because all pin is set as input except B2 that is an output
But this is not my problem because i do not use fast_io.
| PCM programmer wrote: | Maybe I missed something, but do you guarantee that merely
un-commenting the #use rs232() line will make the LED fail to turn on ? |
Yes, i guarantee. Only removing #use rs232 the program starts working.
| PCM programmer wrote: | If it does, I think you should strip down the program to almost nothing.
fail to turn on. | I'll do. Let me to buy some new PICs to test it in a new enviorment. |
redicon
Posted: Thu Mar 01, 2012 7:35 am |
New pic, ccs 4.093.
This code works fine:
//#use rs232(baud=9600,xmit=PIN_B5,rcv=PIN_B2,parity=N,bits=8,ERRORS)
#DEFINE LED PIN_B3
int cont = 0;
#int_TIMER1
cont++;
main()
setup_adc(ADC_OFF);
OUTPUT_LOW(LED);
cont =0;
OUTPUT_HIGH(LED);
This code is wrong, the led starts high:
#DEFINE LED PIN_B3
int cont = 0;
#int_TIMER1
cont++;
main()
setup_adc(ADC_OFF);
OUTPUT_LOW(LED);
cont =0;
OUTPUT_HIGH(LED);
Where is the problem? |
Posted: Thu Mar 01, 2012 10:05 am |
The code runs fine, with your compiler version....
The one thing that changes, is that pin B5, is driven high in the second case.
Are you sure you don't have a wiring short, or are testing the wrong pin?.
