tepes
PIC24HJ128 Invalid Pre-Processor directive Invalid Pin |
Posted: Fri Feb 24, 2012 9:24 am |
Hello everybody!
I want to use pins C9 and C8 for communication but I am geting this eror: Invalid Pre-Processor directive Invalid Pin (chip)!
I get no eror if I use different pins!
In the .h file the only pins defined were C1 and C2 so I have defined the rest of the C pins like so:
#define PIN_C1 5777
#define PIN_C2 5778
#define PIN_C8 5784
#define PIN_C9 5785
Here is a code example:
#define PORT_S PIN_B3
#if !defined(__PCD__)
#error This example will only compile for the PCD 24 bit compiler
#endif
#include <24HJ128GP504.h>
#fuses HS,NOWDT,noprotect
//#fuses FRC,FRC_PLL,NOWDT,NOPROTECT,
#use delay(clock=7350000)
//IT works with the following code:
#pin_select U1TX = PIN_C2
#pin_select U1RX = PIN_C1
#use rs232(baud=9600, xmit=PIN_C2, rcv=PIN_C1,parity=N,bits=8)
//IT does not work with the following code:
/*#pin_select U1TX = PIN_C9
#pin_select U1RX = PIN_C8
#use rs232(baud=9600, xmit=PIN_C9, rcv=PIN_C8,parity=N,bits=8) */
#include <stdlib.h>
#include <stdio.h>
void main(){
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_low_volt_detect(FALSE);
SET_TRIS_B(0xFF);
// B7,B6,B5,B4 are outputs
// B15,B14,B13,B12,B11,B10,B9,B8, B3,B2,B1,B0 are inputs
setup_timer1(TMR_INTERNAL|TMR_DIV_BY_1); // Internal clock
do {
printf("Message\n\r");
} while (TRUE);
Any sugestion greatly appreciated! Thank you! |
Posted: Fri Feb 24, 2012 9:58 am |
Do you have the command line compiler, or the IDE?.
You can fix this in the IDE, with the device editor, simply telling it that the extra pins exist. Each chip has an entry in a database (the devices.dat file), specifying what features it has (pins, peripherals etc.), pin numbers are 'cross checked' with the database before you can use them. There are quite a few oddities like this with the database especially on newer chips, where entries are not complete. 'Classic' is (for example) the PIC 18Fx550 chips, where the 4.3v brownout is missing, which just happens to be the most useful one for USB....
Which 24HJ128 variant are you using?. The GP206, and 506, _do_ only have C1, and C2, and checking the device files, all the other have at least some higher pins defined in current compilers.
tepes
Posted: Fri Feb 24, 2012 10:13 am |
I use GP504 and I dont have the IDE...
I have defined in the .h other pins for ex. PIN_A0 to PIN_A8 and I get no error when using them...Like I said, I get this error just for pins C8 and C9!
Thank you! |
jeremiah
Posted: Fri Feb 24, 2012 1:20 pm |
One thing you can try as a work around is manually set the pin selects yourself. It might require a small block of assembly, but if you have to use those pins, that is one way that might work (see page 140 of the data sheet). |
Posted: Sat Feb 25, 2012 3:30 am |
What compiler version?.
The current compilers do have these pins on the 504.
You must have a very early version when support for these chips was added. Have tracked right back to 4.099, and the pins are there.
If you legitimately own the compiler CCS will do an upgrade for this, either supplying a .dat file, or even possibly a full upgrade.
You can always talk to individual pins using the 'trick' of a bit mask, and pin number/8. So:
#define outputhigh_expin(x) bit_set(*(x/8),x&7)
#define outputlow_expin(x) bit_clear(*(x/8),x&7)
However you have to control the tris yourself, and can't use these for things like comms.
Seriously if you compiler is that old, it is likely to have a lot of other faults as well.
tepes
Posted: Mon Feb 27, 2012 2:45 am |
First off all I would like to thank you for your answers! I will try to use them in order to solve my problem!
I am using MPLAB version 8.80!
One more thing: when i comand the pins like this:
Quote: | if(LOGIC)
output_high(PIN_C9);
output_low(PIN_C9); |
I get the correct signal on the scope: so I can use the pins but not like this:
#use rs232(baud=9600, xmit=PIN_C9, rcv=PIN_C8,parity=N,bits=8) |
In the second example I am getting the error! |
jeremiah
Posted: Mon Feb 27, 2012 10:20 am |
He means what CCS compiler version are you using? MPLAB is the IDE. The CCS compiler version is located at the beginning of the LST file generated.
I tossed your code into 4.129 and it compiled the RS232 code with PIN_C9 and PIN_C8 without any problem. It didn't like your call to setup_low_volt_detect() though, so I commented that part out.
As a side note, if you do manage to get it to compile, I would suggest using:
#use rs232(UART1,baud=9600, parity=N,bits=8,ERRORS)
instead of
Answer back with which CCS compiler revision you have. |
FvM
Posted: Mon Feb 27, 2012 11:49 am |
Coding of #pin_selects isn't a user editable feature in the device database. Missing features or errors have to be fixed by CCS. There have been various problems related to #pin_select with previous compiler versions, not all updates are noted in the version log.
#pin_select functionality of PCD can be however completely bypassed by writing peripheral select registers directly in your code. |
tepes
Posted: Tue Feb 28, 2012 2:15 am |
Sorry for the confusion! I use CCS PCD C Compiler, Version 4.084! So it looks like this is the problem! I did not realise that this CCS version is that old...but it looks like you all use 4.099+
Once again, thank you all for your help! |
