GSM command
CCS-Festina
GSM command
PostPosted: Tue Feb 21, 2012 5:20 pm     Reply with quote
I want to understand the operating principle of GSM, otherwise, I will order a GSM module by a peak (sms sent, receives sms).
ezflyr
PostPosted: Tue Feb 21, 2012 5:35 pm     Reply with quote
This is a CCS 'C' forum. Is your interest in the context of interfacing the GSM module with a PIC programmed in CCS 'C'?
John
zaremchichak
PostPosted: Wed Feb 22, 2012 12:18 am     Reply with quote
GSM module usually use UART. It's easy. Commands for GSM module you can find in pdf for your module.
CCS-Festina
Yes
PostPosted: Thu Feb 23, 2012 12:51 pm     Reply with quote
ezflyr wrote:
John
yes
ezflyr
PostPosted: Thu Feb 23, 2012 8:21 pm     Reply with quote
OK, fair enough, but your question is much too vague. What, specifically, do you need to know about using a GSM modem with a PIC micro? As already noted, most have UART that will connect to the PIC. Which GSM module have you got?
John
CCS-Festina
ok
PostPosted: Fri Feb 24, 2012 8:42 am     Reply with quote
I made a wish, PIC + GSM module, this system is a state supervised, for example, I want to let this system in the house when an event occurred at home he sent me a message on my phone to give me this information
ezflyr
PostPosted: Sat Feb 25, 2012 8:32 pm     Reply with quote
Looking at 'triggers' (digital inputs, analog inputs, etc.) and then sending text messages in response is pretty straight-forward. I did a similar project using the ADH 8066 GSM module. Here is where you can get one:
http://www.sparkfun.com/products/10138
I'd also recommend that you get one of these evaluation boards to help get you up to speed using this module
http://www.sparkfun.com/products/10164
Once you've got a handle on the commands this module accepts, it's pretty easy to connect the module to a PIC and make it do what you want.
John
