Chaud
Strange errors after re-installing CCS c compiler |
Posted: Wed Feb 22, 2012 8:54 am |
Hello, I had to format my laptop, and after installing CCS c compiler, I'm having compile errors that I don't have before format.
For example here:
Code: | int32 readGyro(){
int32 gyro;
int value1;
int value2;
i2c_start();
i2c_write(209);
value1 = i2c_read(1);
value2 = i2c_read(0);
i2c_stop();
gyro = make16(value2,value1);
return gyro;
I cannot see any syntax error, and there isn't, because I compiled this so many times, now when I try to compile I get errors like this:
I really don't know how to solve syntax errors that don't even exist :P, so I think its some problem with installation, anyone can help me with this??
Thanks,
Chaud |
Posted: Wed Feb 22, 2012 9:07 am |
First, the error may well exist!....
Unless this is 'untouched' code that has compiled before, with _everything_ unchanged, the commonest cause for this is an error dozens of lines earlier.
CCS, tends to 'plough on' when it meets an error, and flags the error as happening at the first line that it can no longer compile.So an error, can give you an error shown as being somewhere far latter.
Have you rebuilt the project, or did you bring it across from a backup?.
Another typical cause for this, is that the .pjt file is looking in the wrong location for something. So unless the actual directory layout is identical from the old machine, you need to make a new project, or amend the old one.
So, 'step back'. Verify the compiler is actually working by compiling one of the example programs. If you still get an error, try installing the compiler again (you can get odd behaviour like this from a corrupted .dat file).
If it then works, rebuild the project, and see if this solves the problem. Make sure the new project does point to the right sub-directories.
Linuxbuilders
Posted: Thu Feb 23, 2012 3:42 am |
I used to have this problem too, so when I've got stable ccs release for my chips then I do not upgrade it. Second I had problems with code edited in mplab and moved to ccs ide, there were hidden control bits in the code and I had to rewrite all by hand (CCS does not see it, MPLAB puts there things like code warp, etc). Third do not use mplab because it has own brain and tries to fix your errors which leads to odd problems. Since I use CCS IDE no problems anymore.
So first suggestion - get stable ccs (I use 114), second - copy and paste BIG NONO, write your code by hand and try to see it it will work then. If CCS gets corrupted then you have to kill windows, I had to do it too once. So then I was using VM ware to make life simple, in the end I have installed IDE and CCS on my Wx64 machine but once and no upgrades at all after it. Hope this helps _________________ Help "d" others and then you shell receive some help from "d" others. |
