18F4620 and AN12 setup
Posted: Sun Feb 19, 2012 3:45 am
Hi, I have a problem:
I use in my circuit AN0 to AN4 and then AN12
So to set it up I use:
setup_adc_ports(AN0_TO_AN4 | VSS_VDD); //set AD ports AN0 to AN4
How do I get AN12 setup if 18F4620.h does not have this option? I cannot set up ALL because I use other pins as I/O pins. I use external OSC too.
Is there any way I could do this part manually? If there is please could you help and put detailed instruction bit by bit. I have never done it before and I have no clue where to look for an answer. If there is any way to do it manually by registry modification I would like to ask for detailed examples, I do not know ASM so I depend on .h files.
