software rs232
paolope
software rs232
PostPosted: Thu Feb 16, 2012 3:46 am     Reply with quote
hello,
I chose pic18f26k80 for its 2xUART, but the second shares the pins with ICDU64 so I think to use a sw rs232.
The question is
running it at say 9600, is it interruptable?
paolo
asmallri
Re: sotware rs232
PostPosted: Thu Feb 16, 2012 4:45 am     Reply with quote
paolope wrote:
hello,
The question is
paolo
The standard CCS software UART using bit timing. Interrupts will corrupt the bit timing however if you clock speed is very high (40MHz) and if interrupts are very infrequent and the interrupt handler processing time is very very very short then it should be possible.
Naturally a far better solution is to use the second hardware UART then, failing that, use a timer based interrupt driven software UART.
Regards, Andrew
PostPosted: Thu Feb 16, 2012 5:08 am     Reply with quote
Also remember the software UART is half duplex only, and that you must poll (with kbhit) the incoming data line at least something over 20000* per second if you are not going to miss arriving data....
PostPosted: Thu Feb 16, 2012 9:51 am     Reply with quote
use the debugger between your ears
Very Happy
if you are already using the primary serial port-
that ALONE is sure to eventually corrupt any SW RS232 you may attempt .
only pain awaits you if you go that way.
the 2nd RS232 hardware port is WAY more valuable for its intended use
ICD is for the easily confused anyway -
PostPosted: Thu Feb 16, 2012 2:53 pm     Reply with quote
sw rs232.
The question is running it at say 9600, is it interruptable?
Download the compiler manual and put it on your desktop.
Look in the #use rs232() section. You will find a parameter which disables
interrupts temporarily while transmitting or receiving a byte when using
a software UART.
PostPosted: Thu Feb 16, 2012 4:08 pm     Reply with quote
As a separate comment, you are presumably aware that MicroChip makes a version of the 26K80 for debugging, which has extra pins, and a 'carrier', so you can use the ICD, and the hardware UART....
paolope
PostPosted: Fri Feb 17, 2012 2:21 am     Reply with quote
Unfortunately I had the "nice" idea to migrate from a 18f2523 to a 18f26k80 on an existing PCB, with "just a couple of wires".
So, as usual, I got extra sw and extra hassle.
paolo
n-squared
PostPosted: Fri Feb 17, 2012 3:55 am     Reply with quote
Hi
I pulled out a piece of code from a project I did a few years ago, that implements an interrupt driven software UART.
Feel free to use.
// description: complete software UART using 1 external
//              interrupt and a single timer.
//              Both TX and RX are interrupt driven, freeing
//              application to execute other tasks.
//              FIFO sizes for both TX and RX can be modified
// written by:  Noam Naaman
// functions:   COM2_init() initializes TX and RX
//              COM2_send_chr() adds a character to outgoing FIFO
//              COM2_get_chr() retrieves oldest character from incoming FIFO
//              COM2_chr_ready() returns TRUE if incoming FIFO contains a character
//======- type definitions =================================
#define UINT  int16
#define UCHAR int8
#define ICHAR signed int8
#define bit   int1
#define ULONG int32
//======- COM2 definitions =================================
#bit COM2_OUT = PORTH.1
#bit COM2_IN  = PORTB.3
#define COM2_POLARITY 1 // inverse output
#define COM2_RX_LEN 16
#define COM2_TX_LEN 16
bit    COM2_tx;                 // transmitting a byte
UINT   COM2_tword;              // transmit buffer for start, 8 data, stop bits
UCHAR  COM2_tbits;              // transmit bit counter
UCHAR  COM2_tbuf[COM2_TX_LEN];  // transmit data buffer
UCHAR  COM2_tcnt;               // bytes to transmit
UCHAR  COM2_txi, COM2_txo;      // buffer input/output pointers
UCHAR  COM2_rx;                 // receive bit count
UCHAR  COM2_rbits;              // receive bits
UCHAR  COM2_rbuf[COM2_RX_LEN];  // receive data buffer
UCHAR  COM2_rcnt;               // received bytes
UCHAR  COM2_rxi, COM2_rxo;      // buffer input/output pointers
//======- COM2 software UART ===============================================
#ignore_warnings 225
#int_EXT3 high
void RX_start_bit(void)   // UART input on RB3
/*  TMR2 = 0;
  PR2 = 150;           // set timer to middle of first data bit
  TMR2IF = 0;          // clear interrupt flag
  TMR2ON = 1;          // enable interrupt*/
  setup_timer_2(T2_DIV_BY_4,51 ,2);         // 75uS interrupt for middle of bit 0 at 32MHz for 19200 Baud
  set_timer2(0);
  COM2_tx = 0;         // disable transmission
  COM2_rx = 0;         // initialize bit counter
  disable_interrupts(int_EXT3);
  clear_interrupt(int_timer2);    // start bit collection interrupt
  enable_interrupts(int_timer2);
#int_TIMER2 high
void COM2_isr(void) // software UART @19200bps
  if (COM2_tx) // transmitting?
    COM2_OUT = (make8(COM2_tword, 0) & 1);
    COM2_tword >>= 1;
    if (!--COM2_tbits)
      if (!COM2_tcnt)  // no more chars to send?
        COM2_OUT = 1;
        COM2_tx = 0;
        disable_interrupts(int_TIMER2);
        delay_us(10);
        clear_interrupt(int_ext3);   // no more chars to send, switch to receive mode
        enable_interrupts(int_EXT3); // prepare for next char
      else            // more chars to send
        COM2_tword = (0xff00 | COM2_tbuf[COM2_txo]) << 1; // add start and stop bits
        COM2_tbits = 10;
        if (++COM2_txo >= COM2_TX_LEN)
          COM2_txo = 0;
        COM2_tcnt--;
  else    // in receive mode
    if (!COM2_rx)
      setup_timer_2(T2_DIV_BY_4,47,2);         // 52uS interrupt at 32MHz for 19200 Baud
    set_timer2(5);
    COM2_rbits >>= 1;
    if (input(PIN_B3))
      COM2_rbits |= 0x80;
    if (++COM2_rx >= 8)
      COM2_rcnt++;
      COM2_rbuf[COM2_rxi] = COM2_rbits;
      if (++COM2_rxi >= 16)
        COM2_rxi = 0;
      TMR2ON = 0;                 // disable interrupt
void COM2_send_chr(UCHAR chr)
  while (COM2_tcnt >= COM2_TX_LEN); // wait for space in transmit buffer
  if (!COM2_tx)
    COM2_tword = (0xff00 | chr) << 1; // add start and stop bits
    COM2_tbits = 10;
    COM2_tx = 1;
    clear_interrupt(int_TIMER2);
    enable_interrupts(int_TIMER2); // start transmission
    COM2_tbuf[COM2_txi] = chr;
    if (++COM2_txi >= COM2_TX_LEN)
      COM2_txi = 0;
    COM2_tcnt++;
UCHAR COM2_get_chr(void)
  UCHAR x;
  x = COM2_rbuf[COM2_rxo];
  if (++COM2_rxo >= COM2_RX_LEN)
    COM2_rxo = 0;
  if (COM2_rcnt)
    COM2_rcnt--;
  return x;
bit COM2_chr_ready(void)
  return COM2_rcnt;
void COM2_init(void)
  COM2_OUT = 1;
  COM2_rxi = COM2_rxo = COM2_rcnt = 0;
  COM2_txi = COM2_txo = COM2_tcnt = 0;
  COM2_tx = 0;
  ext_int_edge(3, H_TO_L);
  setup_timer_2(T2_DIV_BY_4,51,2);         // 52uS interrupt at 32MHz for 19200 Baud
  clear_interrupt(int_EXT3);
  enable_interrupts(int_EXT3);  // enable RX
BR
NN
Every solution has a problem.
