need help with crystal Fuses setting for 18f26k22
zeeshan ahmed
PostPosted: Thu Feb 16, 2012 1:27 am     Reply with quote
Hi all,
I am stuck in a problem, I think problem arised due to wrong fuse setting or wrong crystal oscillator. I want to use 20Mhz or 25 Mhz crystal oscillator. When i compiled the program, and tested it, I found controller is not running at correct frequency.
Compiler version = 4.124
below is the code i used to test it.
#include <18F26k22.h>
#device adc=10
#FUSES NOWDT,HSH,PUT,NOLVP
#use delay(clock=20M)
#use rs232(baud=38400,xmit=PIN_C6, rcv=PIN_C7)
     while(true)
          output_toggle(pin_c0);
so, what I found is the delay time between toggles is 25ms, instead of 100ms. Confused
Can any one tell me whats is going wrong.
Thank you & Best regards.
zeeshan ahmed
Problem Solved
PostPosted: Thu Feb 16, 2012 2:08 am     Reply with quote
I use the fuse NOPLLEN ... And the problem solved. Very Happy
