INT_EXT
Futé
INT_EXT
PostPosted: Tue Nov 12, 2002 10:27 am     Reply with quote
Well, It's pretty simple!
I don't know how to use Int_ext2
The following code doesn't work:
#int_ext2
__INT()
if (TrameEnCours==0) TrameEnCours=1;
// printf("c");
enable_interrupts(global);
enable_interrupts(INT_EXT); // ?
enable_interrupts(INT_EXT2);
___________________________
Original Post ID: 8801
johnpcunningham
Re: INT_EXT
PostPosted: Tue Nov 12, 2002 10:54 am     Reply with quote
Try it like this:
#int_ext
void isr_ext()
printf("c");
#int_ext2
void isr_ext2()
//your code here
Original Post ID: 8805
Futé
Re: INT_EXT
PostPosted: Wed Nov 13, 2002 1:56 am     Reply with quote
It still doesn't work. I don't think that I've done some silly things but we never know.
Here is my complete source code. The aim is to read RC5 code.
Even if RC5 decoding doesn't work, it should at least send a printf.
#include <18f452.h>
#fuses HS,NOPROTECT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#include <string.h>
#define DATA_RC5 PIN_B2
////////////////////////////////////////////////////////////////// Variables principales
typedef struct {
char Toggle; // 1 bit
char Adresse; // 5 bits
char Data; // 6 bits
} tCodeRC5;
tCodeRC5 CodeRC5;
char TrameEnCours;
char ErreurRC5;
void InitTelecommande();
char LireBitRC5();
void ReceptionCodeRC5();
// Programme principal
printf("Lancement en cours...\n\r");
InitTelecommande();
while (1)
ReceptionCodeRC5();
#int_ext
isr_ext()
printf("c");
#int_ext2
isr_ext2()
printf("c");
TrameEnCours=0;
ErreurRC5=0;
char LireBitRC5()
char i;
delay_us(868);
i=DATA_RC5;
delay_us(868);
if ((i==0)&&(DATA_RC5==1))
return (1);
if ((i==1)&&(DATA_RC5==0))
return (0);
ErreurRC5++;
return (0);
char i,j;
if (TrameEnCours)
ErreurRC5=0;
delay_us(1302);
j=DATA_RC5;
delay_us(868);
if ((DATA_RC5==1)&&(j==0))
j=1;
} else
j=0;
// Lire Bit Ctrl
CodeRC5.Toggle=LireBitRC5();
// Lire l'adresse
CodeRC5.Adresse=0;
for (i=0;i<5;i++)
CodeRC5.Adresse |=LireBitRC5()< // Lire les datas
CodeRC5.Data=0;
for (i=0;i<6;i++)
CodeRC5.Data|=LireBitRC5()< TrameEnCours=0;
// Récapitulation des informations
if (j==1) printf("START\n\r");
if (ErreurRC5==0)
printf("Toggle=\%u;Adresse=\%u;Data=\%u \n\r",CodeRC5.Toggle,CodeRC5.Adresse,CodeRC5.Data);
printf("\%u erreur(s)",ErreurRC5);
printf("Fin de lecture.\n\r");
Another question is: How do you configure a rising or falling edge in "C" like you do ASM ? (in this case I would prefer a falling edge)
And what does INT_EXT interrupt means ? Does this correspond to INT0 ? and INT_EXT1 to INT1 ... ?
:=Try it like this:
:=#int_ext
:=void isr_ext()
:=if (TrameEnCours==0) TrameEnCours=1;
:=printf("c");
:=#int_ext2
:=void isr_ext2()
:=//your code here
:=void main()
:=enable_interrupts(global);
:=enable_interrupts(INT_EXT);
:=enable_interrupts(INT_EXT2);
Original Post ID: 8833
Re: INT_EXT
PostPosted: Wed Nov 13, 2002 12:53 pm     Reply with quote
:=I don't know how to use Int_ext2
I don't work with the 18F series of PICs. But I wrote
a demo program for INT_EXT for the 16F877. It shows
a lot of the important details. It may help with your
18F project. See the following article. It has a link
to the sample code.
<a href="http://www.pic-c.com/forum/general/posts/5016.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/5016.html</a>
Original Post ID: 8853
