Oscillator config / 18F4550
padbol
PostPosted: Sun Feb 12, 2012 3:25 pm     Reply with quote
Hi there,
I wish to configure a 12MHz crystal to be applied as USB clock source and to CPU.
I'm misunderstanding how to procede and I would be very pleased to get some help.
According Figure 2-1 from the datasheet, page 24, 12MHz comes from OSC1-2, then through PLL /3 to get 4MHz.
These 4MHz are converted to 96MHz PLL and divided by 2 to get 48MHz applied to USB.
On the other way, I wonder how to configure the clock system to get 96MHz/2, 48MHz, to CPU using HSPLL.
I'm working on a automation application where treatment speed is critical.
Here are my fuses and use-delay instruction
#FUSES PLL3                     //Divide By 3(12MHz oscillator input)
#FUSES CPUDIV1                  //No System Clock Postscaler
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES VREGEN                   //USB voltage regulator enabled
#use delay(clock=12000000)
I tried to erase "setup_oscillator" line but nothing happened ; So I undeleted it.
What does that line really do? According to CCS manual, it's used to work with RC internal oscillator ... which I want to cut off.
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
Could you please give me more information on the way to procede? And/Or a bit of source code to help me?
Thanks so much
- Be the change you want to see in the world (Gandhi) -
PostPosted: Sun Feb 12, 2012 4:33 pm     Reply with quote
I wish to configure a 12MHz crystal.
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=31879&start=2
padbol
PostPosted: Mon Feb 13, 2012 3:22 pm     Reply with quote
Except the "Use Delay" instruction, I don't really see a difference between what I did and what you suggest.
Here is the complete list of the fuses I configured.
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL                    //High Speed Crystal/Resonator with PLL enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES ICPRT                    //ICPRT enabled
What about "setup_oscillator" instruction?
I can plug an oscilloscope to an output pin with
while (1) {
   output_high(PIN_XX);
   output_low(PIN_XX);
But what frequency should I measure?
PostPosted: Mon Feb 13, 2012 3:27 pm     Reply with quote
Don't measure frequency like that. Use the LED blinking example in the
link that I posted. It's much easier.
With the code you posted, it's necessary to look at the .LST file and
count instructions, with normal instructions counting as 1 cycle, and
jump instructions as 2 cycles (if they take the jump). Then you have
to know that the instruction cycle frequency is the oscillator freq/ 4.
Use the example code I posted. It's much easier.
padbol
PostPosted: Mon Feb 13, 2012 3:46 pm     Reply with quote
Great! That seems to works fine!
I also measured delays with oscilloscope : 1000ms is a "real" second on the scope.
Thank you Smile
