MdeVries
Calculate value |
Posted: Tue Feb 07, 2012 9:14 am |
Hi you all,
I'm trying to do some math using the CCS compiler. I'm trying to do some modifications on a value readed by the ADC.
My code:
float xfloat, yfloat;
float DeltaX, DeltaY;
if (Xuit > PreRefValue){
DeltaX = X - PreRefValue;
Xfloat = PreRefValue + (DeltaY / 1,5);
DeltaX = PreRefValue - X;
Xfloat = PreRefValue - (DeltaX / 1,5);
X = Xfloat;
X is an 8bit integer.
The value in Xfloat is always a integer (don't know how to exactly call it in english), a whole number like 1,2,3 etc. What I want is that the number is 1,23 or 3,4. |
Posted: Tue Feb 07, 2012 9:25 am |
Try using '.' for the decimal separator.
You obviously come from one of the countries where ',' is used as the decimal separator. This is _not_ legal in C. In C, the ',' is a command separator, and will cause the lines to be interpreted incorrectly.
How are you actually testing the value of XFloat?. You don't show any output, except it being put back into the integer register 'X'. X can only store an integer, so the value at this point will be converted to integer. So are you looking at 'X', or Xfloat?.
MdeVries
Posted: Tue Feb 07, 2012 9:43 am |
Fantastic, Thank you! How simple can it be! |
